- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
1.5" BORA Wheel Spacers now available for order @ Stage 3
2021 Bronco BORA 6x139.7mm 1.50" Wheel Spacers (Set of Four) BORA-21BRONCO1.50X4
BORA 1.5" Wheel Spacer Features:
There's plenty of reasons why you'd want to push your truck's wheels out an extra inch from it's body, but there's only one way to do it right, and that's with this set of four 1.50" wheel spacers from BORA (shorthand for Bulletproof Off-Road Wheel Adapters). These high-quality wheel spacers help give your 2021 Bronco the aggressive stance and wider track you want with the flawless quality that you need so that you can take your high-powered, aggressive truck build just about anywhere you please. The BORA Bronco wheel spacers are built to handle any application and just about any wheel and tire combination that you have in mind, making them perfect for just about any Bronco that needs some extra room between their body and tires. High-Quality Billet Aluminum Spacers Made in the USA
The 2021 Bronco BORA Spacers are 100% made in the USA with materials sourced in the USA on machines built in the USA, making them some of the most American wheel spacers on the market with excellent levels of quality. The spacers feature a 93.1 hub and wheel centric design that helps ensure a good fit while keeping NVH low, even in towing or performance applications. Each spacer in this kit is CNC machined from 6061-T6 billet Alcoa aluminum and then fitted with 12x1.5mm studs or OE fitment that also accepts stock and aftermarket stock replacement wheels.
Fitment:
May not be legal for street use: these spacers may not be street legal in some states (namely Pennsylvania and Massachusetts). Please check your local laws before ordering.
- Complete set of four 1.50" wheel spacers
- Pushes wheels out for an aggressive look
- Provide clearance for suspension modifications
- Billet aluminum construction
- High-strength steel studs
- Comes with hardware
Fitment:
- 2021 Bronco 4-Door
- 2021 Bronco 2-Door
- Does NOT fit any Bronco Sport models
