Wouldn't be this forum if it went any other way.Lmfao....nobody knew but everybody still mad Hahaha
YesSo, I'm confused (like many here, it appears). Does the Wildtrak bumper (the Standard bumper) COME with fog lights standard?
I never understood what the "capable" front bumper was. It seemed the HD bumper was more than "capable".The Standard Bumper is plastic...
The Heavy Duty Modular Bumper...has a slew of features and is a required add for the brush guard and front steel bash plate options also if you plan to order a winch from the factory... Bring your own fog lamps.
The Capable Front Bumper has been listed in error and is not available as a 2021MY option.
That is Exactly where the Capable is found.. .in the Accessory section down at the bottom. But you CAN not find it if you are pricing say a Badlands.what makes you think the capable bumper is DIO? it wasn't in the accessories section of the BNP
Simply put, the Capable Bumper is a hybrid between the Standard "Plastic" bumper with Fog Lights and the all Steal HD without Fog Lights. So it it Steal + Plastic and is supposed to be able to make use of the Winch Add-on, yet you could not add that with the B&P right now.I never understood what the "capable" front bumper was. It seemed the HD bumper was more than "capable".
Yes, the Bronco can be flat towed but with the proper tow bar setup. The tow hook locations may work by removing the hooks and attaching the towbar brackets to the frame mounts.Can you flat tow off the front hooks of the HD Modular bumper? Any one?
