BernR6
Bernie
Ambler PA
2019 Mazda CX-5, 2018 Mazda 3
If I go 2 door base, do you guys think Ford would sell the wheels and tires that are being offered on the higher end models? Like, would I, for an upcharge, be able to opt for the 33" tire and wheel package being offered as part of the Badlands, but get them on the base? I'm just looking at what I could conceivably have done at time of purchase.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Your dealer will sell you whatever they can get.
deejaybee
Scottsdale
n/a
You'd probably be better off buying wheels and tires aftermarket if you want a bigger size. The dealership/manufacturer will almost certainly overcharge you.
Mountain Bronco
West Virginia
Full size GM SUV
I was trying to compare each of the stock tire sizes by trim. I was interested in total tire height (diameter) and width.
This was to help my decision on adding Sasquatch. I have determined that the minimum tire size for me is 285 70 R17, stock Badlands.
My decesion is now Sasquatch lower trim or Badlands. I do not think the width of the 285 will fit without upgraded Badlands/SQ suspension.
This spreadsheet might help others:
Ford Bronco 2021+ Bronco (6th Gen) Factory Tire Size & Wheel Size Comparisons (Circumference, Diameter, Height, Width, Bolt Pattern, Center Bore) 9540B249-0ECF-4903-AD4F-D490065714C6
Beachin 74
Delaware
Is there a spreadsheet?
Toccoa
Toccoa
Isuzu Rodeo Sport
I did see that thread. I specially wanted to see the comparison across all trims at once.
Got it. Now that it’s in the same thread, I’ll add it to the first post.
ChrisE
New Jersey
Bmw, Mustang, Firebird
From the data dump we learned the range of tire/wheel combos for the Bronco.
Base:
P255/70R16 Bridgestone Dueler H/T 685 (All-Season A/S Tires)
Big Bend:
P255/75R17 Bridgestone Dueler A/T RH-S (All-Terrain A/T Tires)
Black Diamond:
P255/70R18 Bridgestone Dueler A/T RH-S (All-Terrain A/T Tires)
Outer Banks:
LT265/70R17 General Grabber A/Tx (All-Terrain A/T Tires)
Badlands:
LT285/70R17 BF Goodrich All-Terrain TA KO2 (All-Terrain A/T Tires)
LT285/70R17 Goodyear Territory (Mud-Terrain M/T Tires)
Wildtrack, First Edition, Sasquatch:
LT315/70R17 Goodyear Territory (Mud-Terrain M/T Tires)
The base combo is a P255/70R16. Here's how it stacks up to the other Bronco offerings.
*Remember #1 is always the base 255/70R16 tire.
Base vs. Sasquatch, Wildtrak, First edition
P255/70R16 vs. LT315/70R17
Base vs. Big Bend
P255/70R16 vs. P255/75R17
Base vs. Black Diamond
P255/70R16 vs. LT265/70R17
Base vs. Badlands
P255/70R16 vs. LT285/70R17
Base vs. Outer Banks
P255/70R16 vs. P255/70R18
Thanks to @Mountain Bronco for the following table.
I thought the OB has 18's, not 17 inch rims
Toccoa
Toccoa
Isuzu Rodeo Sport
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
from another thread, can the base or even big bend and black diamond run 34" tires?
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
WHERE'S THE WEIGHT???
SpecOpsHippie
Al
Manitou Springs, Co
GMC Denali 2500HD, Audi Q5, Triumph Bonneville
Anybody know the respective offset for each factory wheel?Forgive me please if I missed this.
I know the 17” (wildtrak) are 0mm offset.
teerav
Travis
Mound, Minnesota
Jeep Patriot
I missed this thread! I appreciate the pin. I am sure this was answered elsewhere, but can't really find a satisfying answer.
Ford mentioned the difference between BL and Sasquatch suspension is a lift. Is that just because the 2in difference in the tires or do they actually do something with the suspension?
I ask because I honestly do not know what I am talking about, haha. Also because I am curious in the cost of upgrading to 35s if I dont sasquatch. Would I have to pay for a lift to properly fit larger tires?
