@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
no, and I spent a bit of time a few weeks ago trying all of these setting out. None of them actually changed the behavior of any of the DRL’s, headlights, turn signals, or any other lights. Except for the 06, which did as it advertised, and stopped the turn signals from working and changed the blinker sound to a really fast blink.
After an hour of messing with it I ordered the sticker fab covers lol
stbanning
sean
Bonney Lake
f150 platinum, mazdaspeed miata
Is there an idle time setting that can be changed? I thought i saw somewhere that it was 30 min idle. I ask because for us that want to flat tow the 2.7 behind our motorhome the Brakes on the 2.7 are electric assist but it sounds like the electric assist shuts off around 30-40 mins and the brake bias in the suplemental brake system wont have enough power to apply brakes. i am wondering if its tied to max idle time even if engine is off.
heynow14
Nick
Yorba Linda, CA
2022 Bronco - BL SAS MT LUX SOFT
I'm hearing anecdotal evidence that 2022 owners are having ForScan issues. Anyone have FS success on a 2022 yet?
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
I posted in another Thread about that that it is listed with a pull-down menu for a choice of temperatures I am fine with the temperature of my wheel so I did not change it
Does anyone know if it is possible to ADD the heated steering wheel, and enable via ForScan?
I have a base but am going to order a leather wrapped Big Bend wheel. I know I can't add Lane Assist without the CP360 cameras - the entire wheel assembly is $390 but for $60 I can get a heated wheel to boot.
pfbz
CO
F150 Turbo, 991 Turbo S, 996 turbo, Q5 Turbo
Picked up my 2022 2-door Wildtrak yesterday and trying to do some Forscan adaptations. I was able to change a few settings in various modules, but it fails 100% of the time when trying to change any of the chime settings in the IPC module.
Latest version Forscan, tried both OBDLink EX and Vgate vLinker FS cables with latest firmware.
Any suggestions?
Ford Bronco 2021+ Bronco ForScan Thread forscan erroir - 1
Tex
Cliff
San Angelo
You'd need the button on the dash and the wiring harness at the very least before forscan could help you, and that's assuming everything is plug and play with no missing components.
SLCBronco
Cory
Would you be able to program the windows to lower (for opening the door) when you unlock the doors? Or the perimeter unlock? I’m hoping this is possible, so the the windows stop catching every time my kids open the door. I have no experience with ForScan, but I’m very intrigued by everything that you all are doing.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Can you use the ForScan program with a very old Windows laptop? Have a 12 year old laptop running (barely) Windows 7 sitting in a box for the rare occasion a program is Windows-only.
This isn't the first time processing power has been questioned so maybe a note should be added to the first post.
I run it on an ancient winXP netbook. Pretty much any laptop still in circulation should do the trick.
mattm54
Katonah, NY
None
yes, you can program window opening via the key fob... i did it and it works well... you might also look at the spreadsheet and do the window reset if your windows are not opening and closing right (doesn't require forscan, just a little trick with window buttons)..
Osky305
Oscar
Miami
Wildtrak Bronco
Any suggestions?
Picks of wildtrak
Lrenz66
Lorenzo
2009 f250, 1967 mustang gt, 2014 f350, 2017 gmc
Has anyone figured out how to add climate control to the 8 inch screen?
Osky305
Oscar
Miami
Wildtrak Bronco
Simply beautiful . Happy for you . I got a race red 4 door wildtrak. Estimated arrival is 2/24. I live in Miami. Hard top . Lux . I wanted to add modular bumper but my dealer said I couldn't because that is a constricted commodity so I got the standard one. Wish it was metal instead of plastic but I guess I ain't going to be hitting any mountains here in Miami hahahaha
amccue90
Andrew
Illinois
2021 Badlands
WuNgUn
Ontario Canada
2 door Squatched
You've missed the point of the question. This isn't about global open.
As to the OP, no... ForScan won't be able to change how the window drop/door open works.
