- Sean
- Sep 27, 2020
- 20
- 793
- 2,017
- San Francisco
- Website
- www.serramonteford.com
- '21 Ford Bronco Big Bend, '03 BMW Z4
- Big Bend
I would expect it to be in the same ballpark as a Wrangler (Unlimited is 5800 GVWR)So if I am not towing can I load bronco up to 8000 lbs then how do I calculate gwvr
You're confusing curb weight with GVWR. I wouldn't expect the Bronco to weigh 5300 lbs when a comparable Wrangler Rubicon Unlimited is about 4500 lbs curb weight.Based on this...figure 4dr BL, 2.7, hardtop, lux will be around 5300lb curb weight and with my 3,395lb offroad camper, 2 adults (300lb total), 2 dogs (140lb total), I’ll be 295lbs over the GVWR. Complete BS. It states max tow rating is with driver/passenger both weighing 150lbs and varies based on configuration.
So I want to know what 4dr trim with the 2.7 gets you that max 3,500 towing, because the way I see it is if the 4dr BL w/ 2.7 comes in at lets say 5200lb curb weight with soft top and standard package, add driver/passenger 300lbs, that takes you to 5500lbs and tow rating of only 3,340lbs.
This is consistent with Wrangler Rubicon Unlimited: 5800# GVWR, 3500# Max towing 8117# GCWR Payload of 1351. In your scenario the Wrangler is also over weight. As it sits, it's max towing is actually over the GCWR.
5800-1351=4449# Curb Weight
4449+3500=7949
*People/Dogs=440#
7949+440=8389
8389-8117=272# over GVWR.
*accidentally double counted the tongue weight in the GCWR calculation, corrected now.
