fv9
Camas, WA
2018 Alfa Romeo Giulia Ti Sport, 2005 Lotus Elise, Protoform P3 formula vee, Crossle 32F formula ford
Am I correct in seeing that a 4 door BD with 2.7 has a GVWR over 6000? If so, it looks like it qualifies for the Sec 179 deduction.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Vehicle Showcase
Never cared about this as you have to be a complete moron to overload the car to where is would be a concern anyway
OmahaKevin
Kevin
Omaha
2012 Mustang GT, 2012 Edge
so 2 door badlands with 2.7 is 982 lbs of payload
with 2 200lbs guys that gives you how much?
is that alot? i have no idea if this is enough for overlanding can somebody help?
Leaves you with 582 lbs.
If I'm reading everything correctly the payload assumes a 150# driver and a 150# passenger (300# total). If you have a 200# driver and 200# passenger (400# total) wouldn't you only subtract the difference ... 100#? That would leave you a 882# payload.
EDIT --- I was not reading it correctly. Payload remaining in this example is 582#
Used2jeep
Massachuvian
2007 Crown Vic P71
If I'm reading everything correctly the payload assumes a 150# driver and a 150# passenger (300# total). If you have a 200# driver and 2003 passenger (400# total) wouldn't you only subtract the difference ... 100#? That would leave you a 882# payload.
Maybe. But to a degree I feel it is splitting hairs. I'm firmly in the camp of: be "reasonable" in your load and not necessarily by the book/numbers.
Fatdaddy
Louisiana
Ford Torino
I have no experience specifically with this. Need some simplified help here. I’m getting a Wildtrak. Family of 4 (2 very young still in car seats).
- I understand I can’t get roof rails factory installed. Can they be dealer ordered/installed?
-If I want to install roof rails for kayaks or luggage, what do I truly need to be aware of or think about prior to?
- I understand the 110lbs limit while moving. With the assumption of loading up a roof rack on the WT keeping it under 110lbs, is there a safety concern or just a Ford concern to stay in the Jeep class to be competitive?
My plans are not to rock crawl or anything wild with gear on top, simply traveling to a spot, unloading then loading back up.
Big Poppa
KS
Curb weight doesn’t include the driver or cargo. Per FMVSS 49 571.3: Curb weight means the weight of a motor vehicle with standard equipment; maximum capacity of engine fuel, oil, and coolant; and, if so equipped, air conditioning and additional weight optional engine.
49 571.3
9wranglers-later
I love the way no one ever mentions fuel. Can't see it, it's not there.... As long as they don't start flying airplanes we'll be allright.
Advertisement
Advertisement
