- Banned
- #331
If it was air assist in that the air suspension did not in any way effect the operation of a regular coil spring and only activated to increase spring rate when you needed to haul or tow, that would be fine. I'd still rather not have the extra weight of the compressor etc, but it would at least not be a liability.I don't get the people who are so against the air assisted coil spring suspension... Like, I get it, it could break on the trail. But worst case scenario, you're left in the same situation you'd be in without it, which is just a static ride height
Just like the people who are against power locks... like, worst case scenario, you're left with locks that you need to manually actuate, which is what you'd have if you didn't have power locks in the first place
Edit: Meant air assist suspension. I get the complaints against full on air ride, but air assisted suspension isn't all that bad
That's generally not what we get (do any current Ford products have that?). The Lincoln system linked above, as well as on a land rover or porsche cayenne replaces the coil springs with airbags. If it fails your suspension collapses.
