Metal_Horses
NE Ohio
1971 Bronco, 1969 Mustang, 85 SVO, Mach-e
I wonder what "High-Clearance Suspension" (Option on all but the Wildtrack and FE) is especially on the Badlands? More than a BL suspension?
Metal_Horses
NE Ohio
Is this basically saying that the 4-door models will not offer the manual transmission? I don't see the option for 4-door manual transmission listed anywhere.
Looks like the 10 speed auto is standard on all 4 doors except the Badlands, so I read that as the BL is the only 4-door where you can get a 7 speed manual. :unsure:
Metal_Horses
NE Ohio
According to this option list, it looks like I can get a Badlands with the 7-speed and still get 35" tires. 315/70R17 BSW Mud-Terrain (M/T) (35") are an option. So no Sasquatch package, a High Clearance Suspension and 35" tires all while having fun navigating 3 pedals. :giggle:
AZ4x4
CTS
Excellent Chart!!! I noticed under "Towing Capability" for the Base model it is blacked out. Is this correct that the Base model is not or cannot be setup to tow?
gryphon1231
dj
Miami FL
na
gsides1
George
Birmingham, AL
Honda Civic
Thank you very much! This is so helpful! I do have a question though. I’ll be getting the Black Diamond which comes with Equipment Package 320a. Is there anyway to find out what Equipment Package 320a consists of?
ChiBronco
Chicago
2019 JL
This is great! Thanks for putting this together. Something that caught my attention is that the Wildtrak says the door handles are black. That was surprising because all of the pictures show body colored. I went back and checked it against the options on Ford's website and it says black. Anyways, either the options list on the website is incorrect or the photos are incorrect.
Ford Bronco 2021 Bronco Options and Equipment by Trim [Comparison Chart] 1595962909415
Ford Bronco 2021 Bronco Options and Equipment by Trim [Comparison Chart] 1595962365646
Ford Bronco 2021 Bronco Options and Equipment by Trim [Comparison Chart] 1595962416085
KingBronco
Minnesota
1990 Bronco, 1966 Bronco U13
Golly, guess we will just have to wait and see what is offered in the build/price, but that would be a huge disappointment.
coolrain
Marcus
NJ - Bergen County
2000 Ford Ranger, 2014 Camaro 1LE
wow... so many "optional" things I want with the badlands.... expensive
I think you guys with the first edition are going to see some discount with everything it comes with
We will see I guess
Wasatch
TD
SoCal
JeepJK
Thanks for the positive comments Bronco Fans! I used Office 365 Excel to make my sheet but didn't realize my format would need to change when it was uploaded. The funky colors are a result of my theme not translating very well to the xls format. The process was literally cut from ford.com and paste into Excel, so human error was a factor in some of the errors being pointed out.
The mods were kind enough to convert this to pdf so you could download without fear of getting a virus which is awesome. I encourage you to call out any other errors. I don't want to burden the mods with making file corrections and converting the files again.
Some of the options not listed, such as garage door opener, were only listed in the Package Descriptions I screenshot at the bottom of the sheet. I didn't want to murky the waters by trying to add them above. Have a great weekend!
YOU THE MAN! Great work.
mgerm89
Matt
Rochester, NY
2018 Ford Explorer
It looks like you can get the 7-speed on the 4-door, per Ford.com specs section.
rcbickle
Robert
Annapolis, MD
Ford F150 FX4, BMW M550i, BMW Z4, Mini Cooper, Bronco First Edition Reservation
I didn't realize the FE would have vinyl floors. Makes my decision to go to a Badlands even harder now.
I think the First Edition and the Badlands will have the same floor systems. Rubber with drains can removable carpet. Maybe I am wrong.
atonge40
Adam
Detroit, MI
2019 Ford Ranger XLT
I've talked to some Ford people about this. It should have the same tow rating as the other trims because it is mechanically identical. However, it doesn't have a factory tow hitch/package. Therefore, there is no tow capability. Put a hitch on it and I'm sure 3500 lbs will be no problem.
I just need the hitch for a rear rack and a small utility trailer.
rcbickle
Robert
Annapolis, MD
We will see I guess
Well, that was my plan when I reserved it... Fingers Crossed!
