Jeep is $2295 for body color. Bronco likely about the same.Any guesses as to what the hard top for a 4-door will cost? Soft top is a big no for me.
Thanks, sounds about right.Jeep is $2295 for body color. Bronco likely about the same.
The Bronco lineup material says the 35” tires are only available with the Sasquatch package. The Sasquatch package also includes high clearance fenders too.So given that the badlands already comes standard with everything the FE has except the headlock wheels and 35’s, and the 2.7 of course.. would it be feasible to say that just adding 35’s when i place my order would essentially be the Sasquatch with a man trans? The brochure said 35’s are an available upgrade, but does not say the 2.7 is needed?
Ok thank you, apparently the spec list I saw was dated and only said the 35’s were an availability option, didn’t say (w/Sasquatch) package. Looks like I’ll be adding my own wheels and tires later unless they make the squatch package available with the man trans. One could only hopeThe Bronco lineup material says the 35” tires are only available with the Sasquatch package. The Sasquatch package also includes high clearance fenders too.
But basically the same thing with 33” tires and smaller fender flares.
Sasquatch requires the 10 speed auto, not the 2.7 and you get a lot more than just 35"s with it. You get a lift, fenders, lockers, tougher front diff, different suspension, etc.So given that the badlands already comes standard with everything the FE has except the beadlock wheels and 35’s, and the 2.7 of course.. would it be feasible to say that just adding 35’s when i place my order would essentially be the Sasquatch with a man trans? The brochure said 35’s are an available upgrade, but does not say the 2.7 is needed?
Ok I knew it had to be auto, didn’t know it could be either 2.3 or 2.7. And as far as the badlands goes, it comes with front and rear lockers, the same bilstein dampers that are included in the squatch package, and stabilizer bar disconnect. Where have you read that it is lifted vs the badlands? Not too worried about the fenders lolSasquatch requires the 10 speed auto, not the 2.7 and you get a lot more than just 35"s with it. You get a lift, fenders, lockers, tougher front diff, different suspension, etc.
Not if you buy it from another county that has lower sales tax. If you reside and buy in WA State, sales tax is based on the dealer's address, not where you live.
I think you're a lot closer on the Sasquatch package price. I think it'll be about a $4k option. This is based off of what the Tremor package costs, $3,975. It isn't exactly apples to apples but I think it's not too far off.My opinion, which some seem to disagree on, is the $3-$4k range for the Sasquatch package. Many people are saying $8-$10k. No way. Look at it this way. There is an almost $7k difference between the Badlands and Wildtrak. When you jump to the Wildtrak you get the 2.7, auto, Sasquatch package and some other goodies. So there is no way the Sasquatch package alone would cost close to $10k.
I think you've got the most logical guess I've seen on price on this one.I think you're a lot closer on the Sasquatch package price. I think it'll be about a $4k option. This is based off of what the Tremor package costs, $3,975. It isn't exactly apples to apples but I think it's not too far off.
Tremor adds:
35” Off-Road Tire – LT285/75R18
• 18” Low-Gloss Black Painted Wheel
• Unique Front Springs – Ride Height Increase
• Rear Electronic Locking Differential
• Front Limited Slip Differential
• Performance Front & Rear Shock Absorb
• Power Driver seat (8-Way) (XLT only)
• Off-Road Running Boards – Textured Matte Finish
• Skid Plates – Transfer Case and Fuel Tank
• Unique Front Air Dams – Approach Angle Improvement
• Water Fording Vent Tubes – Transfer Case & Axle
• Rock Crawl Mode
• Trail Control Mode
• Tremor Off-Road Decal
• Spare – Conventional Road Wheel
• LT285/75R 18E BSW Spare Tire
• Wheellip Molding – Body-Color
Sasquatch adds:
17" black-painted aluminum beadlock-capable wheels
35" LT315/70R17 BSW Mud-Terrain tires
electronic-locking front and rear axles
4.7 Final Drive Ratio
high-clearance suspension, position-sensitive Bilstein™ shock absorbers
high-clearance fender flares
When building a Super Duty, the 7.3L is $2,045 so I'm thinking that adding the 2.7L will be similar. Unfortunately, adding the Sasquatch package requires the 10 spd auto. Not sure what that added cost will be so I've been ballparking it at $2k based on what Jeep charges seeing as they're going after the Wrangler. Just adding Jeep's 8 spd with the base V6 engine is a $2,750 option but if you opt for the 2.0 I4 (a $0 option), the 8 spd is only $1,500.
AgreedNot if you buy it from another county that has lower sales tax. If you reside and buy in WA State, sales tax is based on the dealer's address, not where you live.
It better be discounted for the BL!Next question is will Sasquatch be the same price on all models or will it be cheaper on Badlands where much of it is already standard?
I think it's gotta be cheaper since, like you said, the Badlands basically has most of it standard. If it isn't cheaper to compensate for the standard features of the Badlands, I think Ford would be leaving a lot of money on the table. I want a 4dr Badlands with the extra Sasquatch stuff but if it isn't discounted to compensate, I have no problem leaving the extras it would add. I drove through the last winter without a working heater in my truck and at this point, the only mandatory I want on my 4dr Badlands is the mid package so I can have the remote start and heated seats. I want it to be warm when I get in.Next question is will Sasquatch be the same price on all models or will it be cheaper on Badlands where much of it is already standard?
I was reading somewhere on this forum as well that each model (2 DR and 4 DR) will make around $7500 profit for Ford Motor Co. That means these dealerships have a lot of wiggle room. What we need to find out would be the cost for the dealership to have the vehicle on their lot and offer around 3-5% above that cost. You should never, ever pay MSRP for a brand new vehicle off the lot.Yah that $5k difference between the base 2dr and 4dr is huge as a % of their actual prices. The profit on the 4 door must be significantly more too then. The 2 door Base could be a loss leader to get customers in the door for possibly purchasing higher models, and to be able to compete with the Wrangler Sport on the lowest starting price.
