- First Name
- Joel
- Joined
- Apr 7, 2021
- Threads
- 295
- Messages
- 715
- Reaction score
- 1,298
- Location
- Arizona
- Website
- www.stage3motorsports.com
- Vehicle(s)
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Your Bronco Model
- Badlands
- Thread starter
- #1
Check out the Redline Stainless strut gas shock kit for the Bronco.
As usual message me for forum pricing.
Frank
2021 Bronco Redline QuickLift ELITE Gas Hood Strut Kit 21-11040-03
2021 Bronco Redline Hood Strut Features:
While your 2021 Bronco may be a capable, advanced, and stylish multi-role SUV, one thing that's holding it back from absolute perfection is the bargain bin stock hood prop. The Redline Tuning QuickLift ELITE Max Lift Hood Struts for 2021 Broncos lets you ditch the stock hood prop for good and make it easier to open your hood while giving you more room to get work done under the hood. The Redline Bronco QuickLift ELITE Max Lift hood struts drop right onto your Bronco and feature a pair of gas-charged strut assemblies that completely support your 2021 Bronco's hood and allow for the complete removal of the stock hood prop. Redline's QuickLIFT ELITE Max Lift struts even open the hood 5" higher than the stock prop rod, which gives you more room to get work done and add all sorts of aftermarket parts to your Bronco without hitting the prop rod and bonking your head -- or worse. Stainless Steel Gas Struts with Progressive Internal Design and Easy, Drop-In Installation
The Bronco Redline QuickLIFT Elite hood struts were specifically designed from ground up to give you smooth operation in a drop-in package. Each of the gas struts included in the Redline QuickLIFT kit feature stainless steel bodies that give them excellent corrosion resistance in practically any climate or application. The struts feature a progressive, slow-release internal design that opens the hood quickly, but brings it to a smooth, easy stop at the top of their travel so that you don't cause excessive wear or break your Bronco Sport's hinges. The struts install using Redline's patent-pending attachment system that does not requiring any drilling or permanent modifications to either your Bronco's hood or body for installation. Each QuickLIFT PLUS kit comes with powder coated hardware and installation instructions so that you can get the struts up and running in practically no time.
Fitment:
Will not fit 2021 Bronco Sport: this set of hood struts will not fit 2021 Bronco Sports.
Frank
- Allows you to delete your 2021 Bronco's prop rod
- Pair of high-quality hood struts
- Provides easy opening and improved under-hood clearance
- Adds 5" of total opening height
- Easy, no-drill installation
- Stainless steel struts with powder-coated hardware
Fitment:
- 2021 Bronco 2-Door
- 2021 Bronco 4-Door
