Can you post the pic of that blue bronco that shows up for this thread on the home page? It looks to be a black diamond which I haven’t seen before but there is text covering part of the picture.
To your point, the unfortunate reality (to those wanting a manual 2.7) is that 1st year buyers are the enthusiasts that want that type of combo, but long term, manual sales will tumble to be a small percentage making it a combo Ford won't want to make.Keep in mind, there is a difference between what an OEM considers a good margin of safety, and what the transmission will actually handle. There are also stronger variants of the mti550 that Ford elected not to use for the bronco (because they would be overkill for the 2.3, and there is not enough of a business case for the 2.7)
At the end of the day, if Ford thought they could make a profit by offering it, they would have, but so few people buy manuals already, and most of the die-hard manual people will accept the 2.3 rather than just not buy a bronco.
I suspect in the next gen or refresh of the mustang this same six speed (Without the crawler gear) will replace the one in the mustang.
Was this supposed to be gloss or glass?Will there be an option for a gloss top?
1) most of the body panels are aluminum: https://www.bronco6g.com/forum/thre...erials-construction-on-2021-ford-bronco.3298/@Administrator
1. Why isn't the whole body aluminum like the F150?
2. What colors will have late availability?
3. How much does the Sasquatch package cost for each trim level?
4. How much will the hardtop cost for the 4 door?
5. Will the rubber floor with drain holes be available on all trim levels at some point?
4 - Ford always has trip meters2 door, wildtrak reserved:
1) white hard top available? ( need it out here in the heat of the Southwest)
2) adaptive cruise control available as a stand alone option?
3) additional power outlets ( USB) on dash available as stand alone option?
4) re-settable trip meters (odometers, trip 1, trip 2) in dash/instrument package?
5) "miles to empty" in dash/instrument package?
thnx
Just out of curiosity, how many USB devices do you need to be plugged in at once lol?2 door, wildtrak reserved:
thnx
Where does this rumour come from? Nothing I've seen shows this. The website lists the 4D with the standard, with exception being the Base which shows 2D with MT and 4D with AT.I'd really love to see if this rumor is true or not:
Is the 10-speed Automatic going to be standard on the 4-door models?
see thread: Removable hard top Vs. Modular hard topMy question... Please explain the hard tops! Standard and modular. What is modular hard top?
Thanks
I don't think that rumor is accurate. My reservation is for a 4 door BD with manual transmission.I'd really love to see if this rumor is true or not:
