Status
Not open for further replies.
evan
evan
Seattle
Subaru Crosstrek
I was thinking the same thing! I measured it out actually. the base bronco is 73" tall with 30" tires. the badlands comes with 33" all terrains which brings the height to 76". You add the 35" tires and your height would be 78". so close to 78" height is what the bronco badlands with sasquatch package should be.
Nuance here is that when moving up tire sizes, you're only adding half the difference in height, cuz circles. So 33" tires only get you an additional 1.5" in height from the base, and 35" tires only get you 2.5" in height from the base. And there may be slight discrepancies there too, since a 35" tire may actually only be 34.7", for example. On top of all that, it's not tire sizes alone, since these trims and packages will include different lifts from the base to accommodate the larger tires, but I don't recall seeing the exact specs for Badlands vs. Sasquatch, at least not anywhere official.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
Boston182
San Francisco, California
Harley Davidson Sportster
  • What is the true difference between Sport and Baja mode? And why does the former not exist on Badlands and First Edition?
  • Will the front passenger seat fold flat like the Ford Flex?
  • What is the difference between "Ford Co-Pilot360 Technology" and "Ford Co-Pilot360"? (As they are different line-items in the spec sheet, and the latter isn't available on the First Edition. Why?)
  • Will additional neutral exterior color options be added to the First Edition (Carbonized Gray and Shadow Black)?
  • Will additional interior options be added to the First Edition (literally anything neutral)?
  • Will we be able to see the colors in real life any way before our order? (already been asked, but reiterating)
  • Can the 2-door seats fold flat and fit the doors inside the vehicle? (already been asked, but reiterating)
Will additional neutral exterior color options be added to the First Edition Carbonized Gray and Shadow Black?
Will additional interior options be added to the First Edition literally anything neutral?
Did you seriously just copy and paste my questions? Even though they said to read the posts and not duplicate questions? ?
BuzzyBud
TBD
US
TBD
Two requests for our representative:
1. Did the vehicle have the sound reduction/insulating headliner? Impressions?
2. Did you look inside the lockable compartment between the front seats? Impressions? Did it have a USB port?
Thank you!
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
I feel sorry for whoever the representative is from here . That’s a lot of fucking questions to remember and ask .
Better Take a big note pad ?
Actually, if you filter out all the questions that:
  • Are already answered, either on this forum or on Ford.com
  • Will be easily answered once the B&P tool is live (everything related to prices, colors, and options available on trims)
  • Are just a request to make a major change to the vehicle (not likely to happen at this point, but you could summarize with "Are the features and options currently listed final, or is there room for changes for the 2021 models?)
  • Are summed up as "Why isn't [insert your specific feature here] the way I wanted it?
Then the list of questions that need to be asked isn't really that bad. ;)
MastadonSlayer
Albuquerque, NM
2017 BMW M2, 2023 Brocno BaseSquatch
What is the GVWR going to be on a 2 door vs 4 door, 2.3 vs 2.7?? The curb weight posted seems heavy for the car. So anyway we can get a GVWR over 6001 lbs?
ColoradoGuy
Will there be any update to the information we have to date on towing? Is 3500# the base towing amount and will four doors, larger engines, etc. alter that number? Is that 3500# with a load-leveling hitch or a standard hitch? Will the tow mode have the setting like the F series that allows you to enter the length of the trailer for Blind Spot Warnings?
All of this and to add, what is the towing capacity on 2.3L vs 2.7L, 2-door vs 4-door, and will any of the models or packages (such as the sasquatch package) have varying towing capacity?
Lcubed
l
UsA
ask them what it take to divert the cyber orange 2 door test vehicle with the the 2.3 L motor, 7 speed stick, saddle leather interior and sasquatch package from the crusher into my driveway.
seems like the ultimate unicorn at the moment.
acetdeucy
daniel
Lincoln Corsair Lexus RX350
Please confirm white top, silver grill combo option (will fenders be white). When will Velocity Blue be available for order.
Well... same, except for White Grill option, with all the other noted white accents.
Golden_Oryx
Asif
United Arab EMirates
Nissan Patrol
I’ve got 2 questions:
1) not sure if anyone has inquired about crash testing results on 2 and 4 door..
2) any plans to introduce the performance exhaust system (With on /off switch) as one of the 200 accessories.
JE2ning
Jaime
Subaru Forester
Why is manual transmission only available on 2-door & not the 4-door? & Will they make the manual transmission with the Sasquatch package available?
BunkieDuster69
Don
NorCal
‘19 3.6 OB
Doug,
First and foremost- thanks for your effort and integrity Sir,
I will skip those Q,s that answer themselves , following consumer configurator release... here you go:
1) Which paint colors, if any, are exclusive to the 2021
Bronco line ?
2) Which component(s) ( i.e. engine fan, power seats) Limits h2o fording to 33.5”?
3) What is the projected Bronco production ( #/ week ) if/when MAP increases production to 3 shifts per day (24hrs; including Sat)?
4) In regards to the Badlands, did the 33” tire rise as an optimum choice through testing analysis for the upper tier suspension geometry and Powertrain gearing?
5) What attributes led to concluding the AT tire selection for The Badlands and MT choice for Sasquatch?
6) Plastic or metal oil pans on the 2.7 engine and Auto transmission?
7) Who here enjoys a quality Canadian bacon and pineapple pizza? ( those who raise their hands could possibly receive a bronco6g decal from our rep!)
Ford Bronco 2021 Bronco Ride Along Event (Next Week) – Submit Your Questions! 2E35C4D1-1571-4F12-BCD0-95D8353210D7
Whelan007
Austin
2019 Jeep JL
Same questions
Status
