2021 Bronco Rough Country 1" Spacer Kit 40300
Stage 3 Motorsports
Frank
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
Rough Country has released their 1" Spacer kit for the 2021 Bronco (see fitment notes)
(These are presently in stock at RC and would ship direct to you)
Bronco Rough Country 1" Spacer Kit Features:
  • Levels the front with the rear
  • Bolt-on installation
  • Retains factory ride quality
  • Increased ground clearance
  • No need to disassemble struts
  • Includes lifetime manufacturer warranty
Aggressive Stance
Feel the thunder in Rough Country's 1 Inch Spacer Kit for 2021 Broncos. Provide your rig with properly designed ground clearance that allows for implementing larger tires into your build. Greater ground clearance allows for you and your Bronco to take on tougher trails. This upgrade is an easy way to blow your friends out of the water on any adventure, not to mention it helps prevent damage to your undercarriage. So, if you take your off-roading skills seriously you should know that a lift kit is virtually mandatory. By adding these spacers to your Bronco you can eliminate the standard nose-down stance that plagues our streets these days. Chest up and out, it's time to upgrade. Quality, Long-Lasting Construction
Laser cut front and rear upper strut spacers make for a perfect for to your 2021 Bronco. There will be no hassle whatsoever to install this kit, especially considering the installation process is 100% bolt on. The best part is that with this kit you can avoid dealing with the complicated process of tearing apart your existing struts. Powder coated in black, the spacers were designed to resist any element you put your Bronco through. With a lifetime replacement guarantee from Rough Country, you can't go wrong lifting your Bronco with this kit.
Fitment:
  • 2021 Ford Bronco
  • Does NOT fit Bronco Sport models.
  • Does fit Bronco Badlands and Sasquatch models.
Recommended Wheel and Tire Configuration:
  • Max Tire Size: 35x12.50R17
  • Max Wheel Size: 17x8
  • Max Offset: +31
Advertisement
4x4TruckLEDs.com
Advertisement
