Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
Another, more affordable for winch mount for those in the market.
2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 1633036438005
2021 Bronco Rough Country Hidden Winch Mount Features:
  • Adds clean, low-profile winch mounting and protection
  • Compete winch mount and skid plate kit
  • High and tight install under the stock bumper
  • Compatible with Rough Country 9500S and 12000S winches
  • Requires minor frame trimming for installation
  • Comes with install hardware and instructions
  • Will not fit Bronco Sport
Adds a Clean, Low-Profile Mount for Rough Country's Winches on your 2021 Bronco
The 2021 Broncos may be able to hit the dirt and the trails straight off the showroom floor, but tackling tough terrain without a good plan B and a good recovery solution is never a good idea. The Rough Country Hidden Winch Mount Kit for 2021 Broncos gives your aggressive, off-road Bronco build some extra protection and an extremely clean, low-profile mounting solution for one of Rough Country's high-quality winches or similarly-sized winches. The Rough Country Bronco Hidden Winch Mount tucks tight under your 2021 Bronco's front bumper and features a cutout for a fairlead and is even compatible with Rough Country's Tow Hook Shackle Conversion kit so that you get a bunch of different recovery options. Each mount and skit plate has an awesome, angular design that gives your 2021 Bronco a vicious, tough look that is sure to turn some heads. The winch mount includes an integrated skid plate to replace the factory guard panel and installs using a combination of the stock mounting mounting points and included hardware, though some frame trimming is required for final installation. Complete Winch Mount Kit with Integrated Skid Plate made from Powder Coated Steel
The Rough Country Bronco Hidden Winch Mount is built extremely tough so that it can handle and survive tough off-road and overland applications without letting you down. Both the winch mount and the skid plate are made entirely out of steel and come topped off with a textured black powder coat finish that keeps them protected from corrosion in almost any climate and application. The skid plate comes with laser-cut "RC" lettering that gives the entire kit a great look. The winch mount was designed to work with Rough Country's 9500S winch or Rough Country's 1200S winch with synthetic ropes. The winch plate features a standard 10x4.5" bolt pattern, and other winches of similar dimensions to Rough Country's winches may fit. The Rough Country winch mount requires some frame cutting for installation and comes with install hardware and instructions.
Fitment:
  • 2021 Bronco 4-Door
  • 2021 Bronco 2-Door
Will only fit Broncos with tow hooks: this kit will only fit 2021 Bronco models with OEM tow hooks.
Will not fit Bronco Sports: this hidden winch kit will not fit Bronco Sports.
More photos:
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 10
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 9
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 7
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 6
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 5
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 4
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 3
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 12
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Looks like a great solution to have a winch without blocking the camera. Does it affect ground clearance in any way?
Being that is is newly released I have yet to see one in person so can only comment from what I see. Based on that I would say no, maybe sitting a bit lower that the bumper/skid up front but no lower than the front cross member so overall clearance would remain the same.
DREWR13
DREW
ATLANTA GA
2003 Miata....
Approach angle is the only thing I could see being negatively impacted. I'm still very interested though.
Will this fit the modular front bumper?
dgorsett
colorado
F250, Mustang, Explorer
Yes, yes, yes. I had something similar on a couple Bronco II's and a Ranger, very nice. Folks will say it hangs too low, and for deep mud maybe, but if you're crashing into rocks there your not going anywhere anyway. Only issue for me is I've ordered the Blue Ox Towing Base plate which mounts to the same locations. It's currently backordered and if it doesn't show up first I could get this and mount the towbar to the shackle points.
EDIT: One concern for using as a towbar mount, the instructions say to install the shackle mounts loosely then pull forward as far as possible, The holes are slotted and would work fine when pulling, but might not hold in braking when the towed pushes forward.
j_marinelli
Spring Branch, TX.
Theherofails
Thomas
Phoenix
I just took these photos yesterday of the factory winch setup. Terrible.
I'm interested in this rough country setup, but I'm curious of the winch quality. Anyone?
Also, are you guys allowing local pickup yet?
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 20210929_154342
Ford Bronco 2021 Bronco Rough Country Hidden Winch Mount & Skid Plate Kit 51054 20210929_154353
dgorsett
colorado
Would like to see the installation instructions. I didn't see them on your site.
Instructions are on the Rough Country site. The tow hooks shown apparently don't come with the kit, you buy separately. You can reuse factory hooks or get the RC ones. They sell the shackle type tow hook mount separately.
acnp2022
CT
ford
Seems great but rough country stuff like this is only Compatible with the stock bumper.
Jason hamilton
Jason
Knoxville TN
Tahoe
Not sure of winch quality, but the mount and winch are sold separtely.
Theherofails
Thomas
Phoenix
I know, but from what I see, the mount is designed to work specific to their winches. I'm not a winch kind of guy usually, so not sure if mounting is universal between brands.
Rick Astley
Up Doug's ass
d
