- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
Here is a nice little lockable storage solution for the Bronco, ready and available to ship in limited qty.
2021 Bronco Rough Country Rear Lockable Storage Box with Drawer System 51057
2021 Bronco Rough Country Storage Box Features:
The 2021 Bronco's aren't exactly loaded down with interior storage options, much less anything that secures your high-priced gear, valuables, or firearms. The Rough Country Rear Lockable Storage Box for 2021 Broncos adds a massive amount of extremely secure storage in a complete system that easily drops into your Bronco's rear cargo hatch without the need for any drilling. The Rough Country Bronco Storage Box features a lockable door, an interior sliding drawer, and a raised design that allows for some storage underneath the storage box. The Rough Country Storage Box for the 2021 Broncos gives you the perfect combination of security and accessibility so that you can keep your gear totally secured from prying eyes and bad intentions while still giving you immediate access to anything you may need inside the storage box. Each Rough Country Lockable Storage Box installs using the factory tie-down mounts and doesn't require any drilling or permanent modifications to your 2021 Bronco build. Durable and Strong 16-Gauge Steel with Black Powder Coat Finish and Easy Installation
Rough Country carefully designed their Bronco Rear Storage Box to be extremely durable and exceptionally secure all while dropping right into your Bronco's rear cargo area. The box is made out of 16-gauge, cold-rolled steel that makes it incredibly tough and resistant to both prying and drilling attacks. The box and mounting brackets are topped off with a textured black powder coat finish that protects the steel components from corrosion while giving the system a great look that fits right in with the rest of your Bronco's interior. The Rough Country Storage Box has a maximum weight rating of 400lbs, letting you securely store just about whatever you need. The brackets feature a raised design that gives the system of 6" of storage under the box itself and allows for access to the stock jack compartment and storage cubby. The storage box installs using the stock tie down mounts and included hardware and doesn't require any cutting, drilling, or other modifications. Rough Country even backs the storage box with a limited lifetime warranty.
Specs:
- Provides a huge amount of secure storage for your 2021 Bronco
- Complete lockable storage box with drawer system
- Features raised design for 6" of under storage
- Installs using OEM tie down points with no drilling
- Heavy-duty 16-gauge steel with black powder coat finish
- Comes with install hardware and instructions
- Backed by a limited lifetime warranty
- Will not fit Bronco Sports
Specs:
- Total Box Dimensions: 23" long x 39" wide x 13" high
- Drawer Dimensions: 21" long x 37.25" wide x 10" high
- 2021 Bronco 4-Door
