SuperFord
2013 Ford Fusion
If the actual tie ROD itself snapped, not just the tie rod end, I don't think that part is individually replaceable on the EPS unit. Even if it is, I believe you are dropping the entire rack to work on it. Probably not happening on the trail.
FWIW, your F-150 and the new Bronco do both have serviceable nner rods AND Outer tie rod ends.
It may exist, but Iā€™ve never seen a steering rack that didnā€™t have both with serviceable parts.
F-150
Ford Bronco 2021 Bronco snaps both tie rods valiantly on extreme obstacle (Queens Throne obstacle on K2 trail) 383E91B6-9F0F-4169-BB5E-F2375A8957A8
Ford Bronco 2021 Bronco snaps both tie rods valiantly on extreme obstacle (Queens Throne obstacle on K2 trail) 814F6902-9D2D-4ECE-9883-B8A3F2DA4CDE
should not require removal of the EPAS rack in either case.
Lazerus
Sean
Las Vegas, NV
Wrangler JL. Land Rover Discovery Sport
Are the tie rods on SFA suspension made any different? Would SFA have made any difference here? I gues my point is, the AXLE didn't break, the tie rod did. Seems like both IFS and SFA would have tie rods that would see similar steering forces during these maneuvers
The tie rod on the JL is pretty beefy even in stock form.
Ford Bronco 2021 Bronco snaps both tie rods valiantly on extreme obstacle (Queens Throne obstacle on K2 trail) remove-stock-jl-tie-rod
That isn't to say it can't be broken - though you are more likely to simply bend it. Shoot we have a trail out here called 'Tie Rod Canyon' - so named because someone once broke a tie rod on the trail and dug it in to the ground as a monument to how difficult the trail can be.
It's part of why Jeep has stuck with the recirculating ball steering system over rack and pinion. It's simply more robust - but it inherently has more 'play' than the R&P. Everything in life is a trade-off
mjohnso3
Marc
Atlanta
FJ Cruiser
I guess I just don't understand the point of just driving up stuff just to do it. The 4 x 4 exists to get me where I want to go. I'm not going to just take a truck out and flog it to see if I can drive over something. I think of it kind of like going to the gym and doing crazy ballistic powerlifting to see if you'll get hurt or not.
That's true for most people, but there's always the " hold my beer" or " ya'll watch this" crowd that keeps the rest of us entertained.
JPG
Montreal, Qc, Canada
Bronco Badlands
I donā€™t believe that to be true. I have seen broken axels without broken tie rods quite often. I have only seen one bent tie rod. On tough trails I carry a spare axel, rear shock, and front coil over. I may carry a tie rod now as well but I have never had an issue and I havenā€™t been with anyone that has.
Corrected, you are right. ( It was a late night post in my defense šŸ™ƒ )
Bronco_joe
joe
Niagara Falls. NY
There are few companies developing stronger outer tie rods but nothing on inner tie rods. I don't think I've ever seen a beefier inner rod. Looks like it snapped right at the jam nut.
jd-ford-hd
Tennessee
ā€˜16 Explorer, ā€˜13 F150, ā€˜99 F350, '74 Bronco
  1. Are the tie rods on SFA suspension made any different? Would SFA have made any difference here? I gues my point is, the AXLE didn't break, the tie rod did. Seems like both IFS and SFA would have tie rods that would see similar steering forces during these maneuvers.
THANK YOU..!!
Felix808
SRV CA
F-150
Yep, really not that hard of a repair if you have parts on hand & a jack stand :cool:
BigFootie
Wisconsin
BigFootie
Wisconsin
How do you brake both tie rod endsšŸ¤·ā€ā™‚ļø
By using the ā€œbreakā€ pedal! Sorry, couldnā€™t help myself. I canā€™t spell either as Iā€™m sure many have noticed! :cool:
Schmack B
Clarksdale, Mississippi
Toyota Tacoma
F-150
Ford Bronco 2021 Bronco snaps both tie rods valiantly on extreme obstacle (Queens Throne obstacle on K2 trail) 1633265481238
This.
Although i would not want to tackle a inner tie rod on the trail.
