- First Name
- Joel
- Joined
- Apr 7, 2021
- Threads
- 295
- Messages
- 715
- Reaction score
- 1,298
- Location
- Arizona
- Website
- www.stage3motorsports.com
- Vehicle(s)
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Your Bronco Model
- Badlands
- Thread starter
- #1
2021 Bronco StickerFab Vinyl Dash Inlay Lettering 21BRONCOINTINLAY
2021 Bronco Dash Lettering Inlay Features:
The 2021 Bronco's interior was designed for utility, and the passenger's side dashboard looks more than a little plain amid all the grab handles and manual buttons. The StickerFab "BRONCO" Lettering Dash Inlay Kit for 2021 Broncos adds some custom styling to the OEM "BRONCO" lettering embossed on the passenger's side dash board, giving your aggressive 2021 Bronco build a surprisingly noticeable interior styling upgrade. The StickerFab dash inlay kit features precision-cut vinyl lettering that drops into the factory letter recesses on the passenger's side dash and are available in a bunch of different color options so that you can find the perfect look for your own 2021 Bronco build. High-Quality Vinyl with a Ton of Different Color Options
The StickerFab Bronco Dash Inlay Kit features high-quality vinyl lettering that's perfectly cut to fit into your Bronco's stock dash lettering. StickerFab recommends a wet install for the lettering, and StickerFab includes a full, three sets of lettering in you chosen color option in case you have some issues with fitting the letters in the tight recesses of the stock dash lettering. The StickerFab lettering kit is available in 16 different color options, including Badlands Orange and Badlands Grey that closely match the OEM Badlands interior trim. The red, white, and blue color option will come with red B and R, white O and N, and blue C and O.
Install and application: StickerFab recommends using a wet install for their vinyl. Ensure that the application surface is clean and free from oils, cleaners, and sealants (i.e. Armor All). Begin the wet install with a cup of water and a drop of low-impact dish soap. Apply the water/soap mixture to the vinyl so that it doesn't initially stick. Once in proper position, press down on the vinyl to press out the moisture. Then apply light heat to ensure dryness.
Fitment:
Ships via USPS: this kit will ship via USPS and tracking information may not be immediately available.
- Complete BRONCO dash lettering kit
- Drop-in vinyl lettering in choice of color
- Installs in the passenger's side BRONCO insets
- 16 different color options
- Includes three sets of letters in case of mishaps
- StickerFab recommends a wet install
- Will not fit Bronco Sport
Fitment:
- 2021 Bronco 2-Door
- 2021 Bronco 4-Door
