Toccoa
Isuzu Rodeo Sport
From the data dump we learned the range of tire/wheel combos for the Bronco.
Base:
P255/70R16 Bridgestone Dueler H/T 685 (All-Season A/S Tires)
Big Bend:
P255/75R17 Bridgestone Dueler A/T RH-S (All-Terrain A/T Tires)
Outer Banks:
P255/70R18 Bridgestone Dueler A/T RH-S (All-Terrain A/T Tires)
Black Diamond:
LT265/70R17 General Grabber A/Tx (All-Terrain A/T Tires)
Badlands:
LT285/70R17 BF Goodrich All-Terrain TA KO2 (All-Terrain A/T Tires)
LT285/70R17 Goodyear Territory (Mud-Terrain M/T Tires)
Wildtrack, First Edition, Sasquatch:
LT315/70R17 Goodyear Territory (Mud-Terrain M/T Tires)
The base combo is a P255/70R16. Here's how it stacks up to the other Bronco offerings.
*Remember #1 is always the base 255/70R16 tire.
Base vs. Sasquatch, Wildtrak, First edition
P255/70R16 vs. LT315/70R17
Ford Bronco 2021+ Bronco (6th Gen) Factory Tire Size & Wheel Size Comparisons (Circumference, Diameter, Height, Width, Bolt Pattern, Center Bore) 2021 Ford Bronco Tires (1) P255:70R16 vs. LT315:70R17
Base vs. Big Bend
P255/70R16 vs. P255/75R17
Ford Bronco 2021+ Bronco (6th Gen) Factory Tire Size & Wheel Size Comparisons (Circumference, Diameter, Height, Width, Bolt Pattern, Center Bore) 2021 Ford Bronco Tires (2) P255:70R16 vs. LT315:70R17
Base vs. Black Diamond
P255/70R16 vs. LT265/70R17
Ford Bronco 2021+ Bronco (6th Gen) Factory Tire Size & Wheel Size Comparisons (Circumference, Diameter, Height, Width, Bolt Pattern, Center Bore) 2021 Ford Bronco Tires (3) P255:70R16 vs. LT265:70R17
Base vs. Badlands
P255/70R16 vs. LT285/70R17
Ford Bronco 2021+ Bronco (6th Gen) Factory Tire Size & Wheel Size Comparisons (Circumference, Diameter, Height, Width, Bolt Pattern, Center Bore) 2021 Ford Bronco Tires (4) P255:70R16 vs. LT285:70R17
Base vs. Outer Banks
P255/70R16 vs. P255/70R18
Ford Bronco 2021+ Bronco (6th Gen) Factory Tire Size & Wheel Size Comparisons (Circumference, Diameter, Height, Width, Bolt Pattern, Center Bore) 2021 Ford Bronco Tires (5) P255:70R16 vs. P255:70R18
Thanks to @Mountain Bronco for the following table.
Ford Bronco 2021+ Bronco (6th Gen) Factory Tire Size & Wheel Size Comparisons (Circumference, Diameter, Height, Width, Bolt Pattern, Center Bore) 1600178977736
Bolt Pattern:
6 x 5.5 (6 x 139.7)
Center Bore:
93.1
HoosierDaddy
Indiana
32.1 x 10 ...great size for snowy roads, pizza cutters basically, swap out for the 315's in the spring.
Cased
middle
dune buggy
Thanks that is one part of the rpm at cruise math
Toccoa
Toccoa
Isuzu Rodeo Sport
So, it had to be done...
Jeep Wrangler Rubicon vs. Ford Bronco (with Sasquatch package)
LT285/70SR17 vs. LT315/70R17
Ford Bronco 2021+ Bronco (6th Gen) Factory Tire Size & Wheel Size Comparisons (Circumference, Diameter, Height, Width, Bolt Pattern, Center Bore) 1594420682206
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S
I've been lurking for a year.My first car was a '67 Bronco, 3 on the tree.
For me, the tire size is kind of a big deal. I love the way the '315's look but would not want to run them through a Wisconsin winter. Not only do I not do any off-roading hard core enough to reuire them, I run dedicated wheel/tire combos for the winter and would not rather deal with huge effective gearing changes and speedometer error. So 32.1 x 10 would be great for the winter with a slightly wider (but not taller) tire for summer.
Wolperdinger
OR
2020 Tacoma TRD Offroad
Around here surface area is king. Snow is too deep to cut to the ground. All the snow wheeling rigs run 40s at ridiculously low pressure.
I for one am looking forward to 35s.
Spooled
Republic of Texas
If the leaked axle ratios are correct, the 4.7 ratio with the 10 speed will turn 2019 rpm @ 70mph with the 315's
Chrome_Pony
Chrome
The Great Land
For sure.
Surface area/contact patch is always king except in very specific circumstances.
One such circumstance is where said pizza cutters can reach the asphalt or hardpack through the snow/slush/mud... which is a situation that many wheelers can attest is vanishingly rare offroad, despite the popularity of this myth.
I suspect most of the provenance of this lies with areas with winter temps that do not remain below freezing. Constant thaw cycling can produce slush depths on street roads that pizza cutters work well in.
I think I'll be aiming for the 285s, since I have 33s on the Jeep and they are more available both in number and brand variability than the 315s.
topher3134
Wherever the Army takes me, middle east right now
2019 F250 Superduty FX4, 2012 F150 FX4, 2007 Wrangler unlimited Sahara
Look no further than 35" tires on a 17" wheel. No need to replace with 315s. Variety of 35" tires way far exceeds all others and u can change ur load range between a lot of options.
Toccoa
Toccoa
Isuzu Rodeo Sport
What brand do you prefer?
