FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
Just a little chart with what information we know as well as speculation. How will the 2021 Ford Bronco stack up to it main competition?
*Edit added Approach departure and break over angles. passenger volume And towing capacity. and sales
Ford Bronco 2021 Bronco Vs the Competition based on estimated specs 8BF77736-44F2-4574-9A2B-A7ADF58FCCE9
Paint
Jack
Oklahoma
Tundra
How is this saying five inches shorter in length than a 4Runner, yet having five inches MORE rear seat legroom? That's a MASSIVE increase in rear seat room. And the 4Runner has pretty good room for the back seat.
That's...Off.
Goes
Roger
Omaha, NE
2018 Jeep Wrangler Rubicon 4 dr.
Ruptured Duck
Patrick
Kennett Square, PA
Rubicon Gladiator
Only thing I would note would be the base engine for the Bronco. Do we know it will be the 2.7 V6 or the 2.3L 4cyl? For the Wrangler the 3.6L is the base motor. One would assume the 2.3L will be the Bronco? Not sure if this has been confirmed but that would still give the Bronco a slight advantage in base trim.
Jalisurr
Oklahoma
'09 Corvette Z06, '97 Mitsubishi Pajero Evo
It's very very likely that the 2.3 will be the base engine with an ecoboost V6 of some form, probably the 2.7 as the upgrade. Nothing officially confirmed, but there's been enough circumstantial evidence and insiders claiming it to make it a good bet.
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
That's...Off.
4Runner 2nd row seats are very far forward. Hence the much larger cargo area and optional 3rd row.
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
2.3 has been leaked and a no brainer with the 2.3 Ranger. Which already makes it best in class torque even over the 2.0 wrangler.
the 2.7 has been heavily rumored and the engineers behind the Bronco R stated that the race trucks engine was ”derived from the stock motor” and it was a v6tt. safe bet is the second generation2.7 from the f150
Paint
Jack
Oklahoma
Tundra
Five more inches is massive though. 4Runner lists something like an inch more rear legroom than a Tacoma, but in function, the 4Runner can seat four 6 footers easily. Tacoma...Maybe one lol.
North7
North Texas
SUV
Great comparison table, thank you. Why did you estimate the Bronco Front Legroom at only 41" yet you show the Ranger at 43"?
For us tall or long legged people we need more then 41".
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
Newer cars sit up higher than older ones. Leg room includes vertical leg room. For instance my new work truck 2019 Chevy the front seat is closer to the wheel than my old 2008. But yet has more legroom because it sits higher.
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
tacoma has over 43” leg room yet 4Runner is just under 42” a lot has to do with arrangement and vertical leg room vs length leg room.
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
All specs are from manufacturers spec sheets. The estimated number (noted with a “*”) are estimates using visual drawing tools, as well as trends in the segment.
Also note that numbers are rounded because who cares about 0.3”
