2021+ Ford Bronco 4 Door GO Rhino Side Steps Now Available
[email protected]
St. Louis
2016 F250, 2013 Ford Focus ST
GO Rhino Panda Motorworks
About Go Rhino
Since 1975, Go Rhino® has remained a leader in the development, design and manufacturing of innovative, stylish and extremely useful aftermarket automotive accessories. For over 30 years, Go Rhino has taken pride in offering products that allow the trucks and SUV owner to enjoy the most from their vehicle.
Our manufacturing facility is staffed with talented, skilled, and passionate personnel who build each Go Rhino product to the highest standards while utilizing the latest technology and processes. Hundreds of hours go into the development, testing, and fitting of each product before it is approved for manufacturing.
The research and development team work tirelessly to bring each new product to life. Once a product is approved, our manufacturing team goes to work. Skilled, trained technicians man some of the most advanced machines for cutting, bending, and preparing our parts for assembly. Precision jigs ensure that each piece fits to exacting standards with welds created by experienced craftsmen or the best robotic welders. Our processes include constant inspections for the best fit. Once assembly is complete, you can count on the highest quality and best-looking finishes, whether it be our black powder coat, textured black powder coat, chrome, or mirrored polished stainless steel finishes. All of our finishes meet or exceed the OE standards for quality and durability. The most advanced, automated powder coat line is constantly monitored for uniform gloss and thickness.
Once the parts are complete, they are packed carefully and stocked in one of our two giant warehouses serving each coast. As product is received, it is placed in one of four staging areas based on how popular the product is and how often it is ordered. Our quickest-moving products are stocked at maximum capacity to ensure that they are in stock for immediate same-day shipping, if needed
RB10 Running Boards
  • Classic Raptor-style design
  • Heavy-duty polyurea bed-liner style finish
  • Optional 4" drop step also available
RB20 Running Boards
  • Modern Raptor-style design
  • Textured black powder coat finish
  • Heavy-duty polyurea bed-liner style finish also available
  • Optional 4" drop step available
Dominator Extreme D6
  • Wide running board/rock slider style board.
  • Punched steel step plate area has raised hex pattern to provide no-slip grip.
  • Optional matching bolt-on 4” Drop steps.
Dominator Extreme D1
  • Full length drop step style board
Dominator Extreme DS
  • Rock slider style step
  • Removable step pads
Dominator Extreme DSS
  • Slider style step with cover plate
Dominator D2
  • Sits closer to the body than the Dominator D4
  • Punched steel step pads offer extra grip.
  • Application specific installation brackets make for faster, easier installation.
  • Patented step and mounting system allow easier, safer entry and exit.
  • No drilling required on most models and body lift kit compatible.
  • Cab length side steps.
  • Main bar made of solid 2 1/2" round tubing.
  • Aluminum steps available separately.
4" 1000 Series
  • 4" oval design
  • Channel mount, wide-oval design with wider, safer step area.
  • Uses the same popular U-channel OE-style brackets from the OE Xtreme series.
  • New end caps have the look of welded end caps.
  • 1000 Series end caps can be replaced instead of replacing the whole bar if damaged.
5" 1000 Series
  • 5" wide oval design
  • New stylish step pad design
  • Channel mount design with wider, safer step area.
5" OE Xtreme Low Profile
  • Bolt-on, no-drill installation for most applications.
  • SuperGrip step pads allow easier, safer entry and exit.
  • Low profile design adds functionality and style to your vehicle.
Advertisement
da_jokker
Jeep Wrangler JK
I really like the look of the extreme DS, but Make some actual rock sliders and then you'll have something.
chris@pandamotorworks
[email protected]
St. Louis
Dominator DSS Sliders, W/ Rub Rail and Optional Full Length Step and Full Length Slider design on bottom surface
This is what we will be installing in a week or 2!
da_jokker
Jeep Wrangler JK
So are you saying the dominar DSS are actual rock sliders that can support the weight of the Bronco? Everything that I had read made it sound like these are just really steps, with some cool design looks to them and not intended to actually be used as rock rails.
DebbieEF
Debbie
Ford Mustang and F250 SD truck
About Go Rhino
RB10 Running Boards
RB20 Running Boards
Dominator D2
4" 1000 Series
  • 4" oval design
5" 1000 Series
Will you be making these for the two-door Bronco? Thank you.
Its Brawnco
2011 F150 Raptor, 1978 F100, 2016 Ducati Scrambler
The DSS's look best imo. Don't hang too low to limit ground clearance and look like they stick out far enough to help with door dings and keeping debris off lower door panels. The manufacturer website doesn't say anything about them being able to support the weight of the vehicle as rock sliders though, which is my only concern.
[email protected]
St. Louis
I am talking with them now on the weight of the vehicle.
So far they have confirmed they are a slider with a full smooth bottom and no bracket hanging down.
Once I hear back on the weight I will let you know!
[email protected]
St. Louis
Just heard back. The mounts and sliders will support the weight of the bronco. They said the only concern they have is its a bolt on unit to the stock frame area & that would be the weakest point.
Hope this helps! We will be doing a full review and install of the DSS in the coming weeks!
Its Brawnco
Awesome, now all I need is a Bronco to mount them to lol
[email protected]
St. Louis
We hope your wait isn't to long
If you need anything please let us know! Happy to get you guys best pricing and service!
da_jokker
Jeep Wrangler JK
Nice yeah let us know. All I need is a rock slider alternative and I'll pull my tube steps from my Order.
But when something says Slider style, to me that means it looks the part, but can't play it.
martyb
Marty
Winneconne, WI
GMC Sierra Denali, VW Atlas
I need to order some, but I have to see them on a Bronco first... probably RB20
Advertisement
Zone Offroad
Advertisement
