2021+ Ford Bronco Billet Chase Light / 3rd Brake Light
DaveInSA
Seguin, Texas
2021 Bronco Badlands 4DR, 2007 Saturn Sky
You can 3d print a cover for the wires
Got an stl? And ooh, where’d that antenna mount come from?
I wonder why ford reversed the pattern for the bolts between the Sasquatch and regular tire carriers in the first place.
Tye
Tye
San Francisco
Porsche GT3, Range Rover P525, Audi Etron Chronos
I made the antenna mount as well
jtgensler
Jamison
Clarion, PA
2022 Bronco
I don't have a 3d printer.... cost to make one & mail it to me?
Is that what it is? different pattern for Sasquatch models? I know mine is Sasquatch/Wildtrak with the holes that don't line up with the bracket.
DaveInSA
Seguin, Texas
From what I've seen on here over the years, yup.
jtgensler
Jamison
Clarion, PA
2022 Bronco
Have you contacted them? I had a problem with one of the hardware pieces for my top and they corrected it very quickly.
As a follow up, last week, Turn told me they'd be sending an adapter plate.
I wasn't thrilled about that & eventually they told me that the adapter plate was a temporary fix while they manufactured new mounting plates.
So I guess we wait to see how long it takes to get an adapter / or the new mount.
Haven't heard anything from them in a week....
DaveInSA
Seguin, Texas
Ouch. They sent me a part for my top and it was here in like 2 days...
TURN Todd
TURN Todd
Todd
Riverside, CA
2023 Ford Bronco
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
Has anyone gotten one installed yet? Having some issues with the wiring harness not matching up to the instructions. I’m also not crazy about cutting up my factory harness to install. My neighbor, who’s Bronco it’s going on has reached out to Turn who advised new harnesses were being made but were several months out.
Tye
Tye
San Francisco
Here is mine, but i built my own harness with more functionality as well as the brake light portion plugs into the factory plug inside the tailgate ( no cutting). i also replaced all the lighting with baja s2 pros, and 3d printed a housing for a baja rock light and acumen camera. one thing i will note is that if you install
this on a bronco raptor; u need to add the brake light bumpers otherwise the whole thing shakes like crazy.
Ford Bronco 2021+ Ford Bronco Billet Chase Light / 3rd Brake Light IMG_6993
Ford Bronco 2021+ Ford Bronco Billet Chase Light / 3rd Brake Light IMG_6997
popo_patty
Caleb
Sacramento
Yea we are thinking about making our own harness that plugs into at this point vs cutting the factory harness.
Do the chase lights strobe?
Tye
Tye
San Francisco
As its sold from turn, the chase lights dont strobe; nor do the brake lights work as running lights like how the oem braptor does. so this
is what i did:
- Baja Design S2 Pro with flood lens on outers
- installed my acumen mirror rear flush mount camera in center on one side
- designed and 3d printed mount for camera and baja designs rock light on other center opening
- Made the brake LEDs 2 stage (on with running lights, increase in brightness when brakes applied)(just like oem on my bronco raptor)
- 3d printed a housing cover over rear dt connector
- added nmo mount for vhf radio
- all wiring done with high grade txl wire
- black titanium bolts
The way i have mine setup is independent control of the outer pair of lights and inner light. so for example, i can flash/strobe the center while outsides are solid, or any other combo i want to set up.
Ford Bronco 2021+ Ford Bronco Billet Chase Light / 3rd Brake Light IMG_7103
Ford Bronco 2021+ Ford Bronco Billet Chase Light / 3rd Brake Light IMG_1866
TURN Todd
TURN Todd
Todd
Riverside, CA
2023 Ford Bronco
Ford Bronco 2021+ Ford Bronco Billet Chase Light / 3rd Brake Light Screenshot 2025-04-01 103458
Here is the wiring diagram.
jtgensler
Jamison
Clarion, PA
2022 Bronco
Just got an email from FedEx that I'm expecting a delivery from Turn tomorrow. Since I haven't ordered anything else, I assume it's the adapter plate.
That diagram would've been helpful to have in the box - I definitely wired mine incorrectly on the 1st try.
