- Josh
- Apr 25, 2022
- 364
- 521
- 176
- Salem Ohio
- 2022 Bronco 4-door
- Badlands
2021+ Ford Bronco Heavy Duty Splash Mud Flap Guards | Available Here
Going rock crawling this weekend? No problem, once installed these are removed within 10 minutes
Tired of picking up road debris and rocks from your driveway? Don't know of any great solution? Do you hate the thought of drilling a bunch of holes inside your body panels? TMB has come up with the perfect solution! Our splash guards only require two small screws for each of the rear splash guards to be drilled. These are similar to the Ford Gatorbacks, but at a fraction of the price!
No need to remove your tires for installation!!
What's included in this package?
- One Driver Side Front Bronco Mud Flap
- One Driver Side Rear Bronco Mud Flap
- One Passenger Side Front Bronco Mud Flap
- One Passenger Side Rear Bronco Mud Flap
- One Complete Set of Mounting Brackets (Powder Coated Aluminum, Rust Resistant)
- All Hardware
- Detailed Installation (Same as Gatorbacks)
- Assembly and initial installation is about 60 minutes
- Fast Release and Go (after initial assembly) less than 10 minutes to remove/install
- 2021+ Ford Bronco 2-door and 4-door First Edition
- 2021+ Ford Bronco 2-door and 4-door Base
- 2021+ Ford Bronco 2-door and 4-door Big Bend
- 2021+ Ford Bronco 2-door and 4-door Black Diamond
- 2021+ Ford Bronco 2-door and 4-door Outer Banks
- 2021+ Ford Bronco 2-door and 4-door Badlands (w/Sasquatch and w/o Sasquatch)
- These DO NOT FIT RAPTOR
- Standard (shown on the Green Bronco, 9" clearance from the ground on the rears and 6" clearance from the ground on the fronts (non lifted, Big Bend)
- Long (Extra coverage and recommended for Sasquatch owners. These have 8" clearance from the ground on the rears and 5" clearance from the ground on the front splash guards mounted on a non lifted Big Bend)
- Extra Long (These have 6" clearance on the rear splash guards and 3" ground clearance on the front splash guards mounted to a non lifted, Big Bend) We recommend these for any lifted Bronco 3" or more.
- Xtra Wide: Additional 1.5" wide for wide tires and more coverage!
