- Doc
- Dec 10, 2020
- 1
- 424
- 912
- Cumming, GA
- Current: 2016 Ford F-150 King Ranch
- Base
Looking good. I have a white basequatch on order.
Thanks. I'll be changing to 37's or 40's after I run through the stock 35's, so I'll order the XL for now and go for the XL Long when I upgrade the tires.
Your 2-door looks good. I like the subtle changes.
Thanks, when did you order yours?Looking good. I have a white basequatch on order.
FYI oracle says they are working on a plate that fits the 2 door better. https://www.bronco6g.com/forum/thre...odule-from-oracle-lighting.30916/post-1557251
It’s a December 2020 reservation. Order beginning of February 2021. Order converted to 22MY in October 2021. Looks like I’ll be converting to 23MY now this month.Thanks, when did you order yours?
Damn, hopefully it gets built soon since their still filling 21 original orders.It’s a December 2020 reservation. Order beginning of February 2021. Order converted to 22MY in October 2021. Looks like I’ll be converting to 23MY now this month.
Quick Removal for off-road driving. When you are ready to tackle a trail or go rock crawling, the strut tower brace can be removed in less than 5 minutes with 2 bolts. This allows you to get greater flexibility out of your Bronco so that you maximize traction.
You are correct and also the reference to car meets and shows.It's looking good. One point to make sure you are aware of is that a strut tower brace on a Bronco doesn't really make much sense other than something to look at. The shock tower is integral to the frame, not the body. And the shock doesn't locate the wheel/tire like a Macpherson strut suspension would. So the forces the shock down sees are so different as to make a bar to "stiffen" it just a nothing more than decoration.
Note in the description of the product Steeda's wink at the lack of functionality of that part by saying:
Thank you for sharing these pictures!Had some lighting upgrades this week, to start the @Diode Dynamics 18" Single Row Straight Clear Combo Stage Series sitting nicely below the BRONCO, the Stage Series Fog Pocket Kit with SS3 White Fog Sport and two SSC2 White Combo Sport all with amber backlighting. The rear has reverse lights tucked up under the rear bumper to each side of the hitch Stage Series C2 2 Inch LED Pod Sport White Combo Standard RBL with red backlighting.
Where did you get that decal?Did a little interior scenery on the dash today.
