- John
- Sep 3, 2021
- 24
- 2,404
- 2,250
- Pennsylania
- X4
- Outer Banks
Both, is my guess. Best scenario at all times, unless your name is Joie Chitwood, is having all 4 corners in contact with Terra firms and even better is when mass is evenly distributed (parked in your garage).So what’s the actual truth here?
But you are going rock crawling or even traversing fallen trees in the woods, you want, no need, the vehicle center of gravity to be inside the outer point of contact with the ground. Anything that abruptly reduces the tires grip to the ground increases chances of disaster as you move forward.
If you can convince you passengers to hang out the high side, like on a sailboat st speed you shift the c.o.g. uphill and preserve stability. But if you high side front passenger suddenly is in your lap, you might be already rolling sideways.
