2022 Forscan
Abecker
Aaron
2022 Ford Bronco 2dr
I’m looking to identify those who own specifically a 2022 model and have successfully used Forscan.
I can not access any modules other than the PCM in my 2022. So I am trying to identify if this an issue with being a 2022 (maybe forscan isn’t updated), or if forscan is now blocked as of 2022, or if I should try a different adapter. Currently I have the ELM 327.
Anyone wish to opine?
pfbz
CO
F150 Turbo, 991 Turbo S, 996 turbo, Q5 Turbo
2022 Bronco.
OK writing changes BdyCM module,
Error writing changes to IPC module
Tried both OBDLink EX and Vgate vLinker FS
Ford Bronco 2022 Forscan forscan erroir - 1
pfbz
CO
I have a MY22 and used Forscan today with no problem. I’m using this adapter.
Can you verify if you were able to change anything in the IPC module, specifically seat belt, door, and key-in-ignition chimes?
I can read the modules, edit the changes either with drop down or as-built edits, but it always fails on the write.
Jaymanire
Jay
Knoxville, TN
2018 Nissan Armada Platinum
I have the same issue with ABS module when I try to enable Sport Mode on my MY22 Badlands w/ Sas
Shotsy
Joe
Massachusetts
'22 Ford Bronco, '18 BMW m240i, '04 Honda Element
I can confirm that when trying to add Sport to my MY22 Badlands, I receive an error and I cannot add Sport using D2dhanover's code. @amccue90, cluing you in so you can update your spreadsheet indicating that adding Sport mode to a MY22 Badlands isn't working. Ford seems to have closed that door...
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Really hope someone figures this out.
My first reaction is this is just a giant FU from Ford to their customers. Absolutely no reason to block this change.
Jaymanire
Jay
Knoxville, TN
I was able to disable the double honk, auto start/stop and increase steering wheel temp. I have not tried other modules. Perhaps the code is different from MY22.
Abecker
Abecker
Aaron
This happens to me when trying to add modes to my OBX
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
Yeah, how dare Ford make people pay for upgrades. I hope someone figures it out, but it’s not a FU from Ford to their customers. Unlocking shit you didn’t pay for is a FU from the customers to Ford.
Natai
Sean
Sacramento
There is no such upgrade offered by Ford. They offer no option to add GOAT modes to any trim.
I'm generally of the mind that artificially limiting features solely through software is an FU.
Customers found a way to unlock a feature that should never have been locked in the first place.
