2022 Forscan
roofone2
Boston
A4
Really?
I tried using latest full version of FORSCAN 2.3.47? Tried two different OBD adapters. Then tried FORSCAN's newest Beta.
Still won't let me write to either the DDM or the PDM for the Global Close change.
Did you change AS BUILT data or not?
You have a 4dr or a 2dr? Just curious.
What version FORSCAN are you using?
Thanks.
I was also to enable global window opening/closing (and add the UI configuration item) for my four door 2022.
Forscan 2.3.47Test.
I changed the values in all of the modules per the spreadsheet...had no issues writing.
Do you get an error?
mark2215
MA
2015 F350
Really?
Thanks.
I used 2.3.47 test version that came out before the full version was released. I have a 4 door. I used obdlink ex and manually changed the data according to the spreadsheet.
ctandc
VA
'22/23 Bronco, 96 EB Bronco
That's what I was wondering. I have an extended license, I'll pull a log this weekend and send it to FORSCAN. I'm wondering if it's a 2dr thing.
I've used FORSCAN a bunch with previous and friends' vehicles. Only other time I had a problem like this (wouldn't write to one particular module on essentially a brand new car) I submitted a support request (need to have a paid license) and they sent me a 'patched' version of the software and it worked great.
I've made other changes, speedo calibration etc - zero problems. It just won't finish the write on the DDM / PDM - works fine on BCM.
Thanks for the info.
ctandc
VA
Forscan 2.3.47Test.
Tried 2.3.47 with the OBD adapter (Switched) I've used for 5+ years with no issues. Decided to go ahead and update to the latest 'recommended' OBD Vlink - same issues. I even tried the latest Beta version of FORSCAN.
It gets a "service procedure interrupted" when trying to write to the DDM / PDM. BCM changes worked w/o issue.
roofone2
Boston
A4
Yeah, based on 30 seconds of googling, look like there's a good chance it's a bug that they may need to fix. Looks like they fix and patch quickly at least: https://forscan.org/forum/viewtopic.php?p=76203
Good luck.
ctandc
VA
ctandc
VA
FYI - forgot to update this. FORSCAN (I purchased an extended 2yr license) sent me a patched version of the program, Global Close now works perfectly.
Jeverall
James
Tampa fl
Jeep Grand Cherokee
Sorry if I missed it on here , but any issues with the FORSCAN rear speaker update specific to the 2022? I have a 2022 OBX waiting for my OBD link to come this week and want to upgrade my speakers next week .
TIA
etmccaus86
Evan
Motor City
'22 BaseSquatch
Has anyone tried using the latest build (2.3.48) on a MY22?
I had to move to a new laptop, so I'm curious if it's worth even trying or if I should just install the test/beta I previously had working properly.
XirallicBolts
Paul
Wisconsin, USA
2016 Flex EcoBoost, 2010 Milan
Just noticed and installed it. I can at least confirm it fixed the 'Service Procedure Interrupted' when editing DDM or PDM on my 2022, global close is now working as expected. I haven't seen any new features beyond that
Frank
Magnolia Nj
2022 Ford Bronco
Hi All,
This all that shows up on my forscan. Does anyone else have additional items that show up on the 22 OBX.
Cobra13
Wade
Upstate NY
2022 BADLANDS BRONCO, 2006 Escape Hybrid
I can confirm that when trying to add Sport to my MY22 Badlands, I receive an error and I cannot add Sport using D2dhanover's code. @amccue90, cluing you in so you can update your spreadsheet indicating that adding Sport mode to a MY22 Badlands isn't working. Ford seems to have closed that door...
Worked on my 22, make sure you have the lastest version of Forscan.
tobands
2022 Bronco OBX , 2014 Escape Titaimium
On my22 OBX with the latest ver of Forscan , I added baja mode, disabled start stop. Seatbelt reminder, dbl honk. No errors or any issues
MTmeterguy
Jeremy
Sidney, MT
2007 Ford F-150
Did you have to do anything different to disable start/stop? I've added Sport mode and disabled FOB horn reminder on my '22 Badlands but start/stop won't disable
tobands
No.. did nothing extra... Check your changes , make sure it's correct and was written .. I used the latest ver of forscan on a win11 laptop
