2023 Outerbanks without factory hitch & wiring questions.
Tigerbug
Matt
Inman, SC
F350 Diesel 4x4
I will be flat towing my Outerbanks behind a 2023 Nexus Ghost Super C motorhome. I need to wire in a 4pin flat connector for when I tow a small cargo trailer behind the Bronco. I also need to set up the Bronco tail lights to function with the motorhome when being flat towed. I have already installed the Curt Trailer hitch to the Bronco, very easy 4 bolt job.
For the wiring I ordered the following from E-Trailer per their guidance.
RM-152-98146-7Roadmaster 4-Diode Universal Wiring Kit for Towed Vehicles - 7-Wire to 6-Wire Straight Cord
Ford Bronco 2023 Outerbanks without factory hitch & wiring questions. rm-152-98146-7_23_tn
C42WRCurt T-Connector Vehicle Wiring Harness with 4-Pole Flat Trailer Connector
Ford Bronco 2023 Outerbanks without factory hitch & wiring questions. c42wr_13_tn
Looking for guidance on making the connections for both of these kits to make lights function as noted above. Before tearing into those kits, did E-Trailer give me the correct parts? If yes, then when installing both does one need to be completed prior to the other?
If anyone has completed this similar job on their Bronco can weigh in, pics & write up is greatly appreciated.
