2DR Auxiliary Fuel Tank
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
Has anyone seen or heard about a way to increase the fuel capacity of the 2DR Broncos? Would like to see the range pushed out to 350+ miles.
And no Jerry Cans or external fuel carriers are not the Answer.
802Bronco
Southern Vermont
2016 XLT F150 Crew, 1999 Ranger, 2002 Mastercraft
SAME!!!
802Bronco
Southern Vermont
I have read other threads and posts about it. The only way to do it is EXPENSIVE!! Because of sensors and vapor recovery, sending units etc. You would have to replace the original tank with a larger one, if Ford could have I suspect they would have. Add another complete tank for a dual tank set up with all the same systems in place. The one way I think most simple but probably dangerous? Gerry cans on either side of the spare with a hard plumbed transfer pump mounted underneath. You could ad 10 gallons. But what happens if you get hit??
mdonathan56
mdonathan56
These folks are supposedly working on one. The downfall is it'll cost $2,000+ and that's not including install.
https://longrangeamerica.com
Right now I didn't see anything listed on their page for Broncos.
Just signed up for their Newsletter so we'll see what we get.
Arrmjr
Rick
SW Washington
Honda Accord and Civic
It would be like a Pinto!
grayshadow
Charles
Humble, Texas
It always seems I need to stop and pee before 350 miles anyway.
mdonathan56
mdonathan56
Docindahouze
Doc
Cumming, GA
Current: 2016 Ford F-150 King Ranch
yeah an aftermarket replacement tank would be nice. My current f150 had the 36 gallon tank which is really nice for that. Before that I had an f250 on which I installed myself, a transfer flow 50 gallon replacement diesel tank. The range was amazing. I’ll be trading my f150 for the two door Bronco. The one and only thing I’m not looking forward to is the small fuel tank.
swampgoat
jeff
b.c. canada
95 bronco xlt 5 speed manual, 2020 f350 tremor
Too bad they didnt come with a dual tank option like the original. I get about 500KMS to a tank on my 2 door badlands 7 speed.
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Wonder if there's an AM 18g or retrofit a 20.8 from a 4dr
