3.0L Ecoboost
Rsimon
Ryan
Louisiana
F250,early broncos,samurai,explorer st
Been lurking for a while but thought I should share this. I got tired of waiting and bought my wife a new Ford Explorer ST. I own two early broncos and definitely love my V8’s but that 3.0 in the Explorer is crazy! I think it would be plenty for the new broncos. Way more power than I expected. We will just wait a while and give them time to get the bugs out and come off of retail pricing.
Nickp
Nick
Phoenix
Imma keep it real, my 4-door Jeep has the 205 HP 3.8l. It’s on 33’s with the 3.21 gear ratio (manual trans) and it is perfectly adequate. The 2.7 or 3.0 Ecoboost will be faster than I could ever realistically need and will likely get me in trouble lmao.
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
current Wrangler with the right package hits about 0-60 in about 6s
explorer 2.3 hits about 6s
Explorer 3.0 hits about 5s
bronco likely will be faster if it has a street rear end. Throw on the low 3.7-4.0:1 rear and it will take a hit. But you could be talking about high 4s possibly on the 2 door. TROUBLE for sure
MaverickMan
Shane
Does anybody have any insight on the actual differences between the 2.7 and 3.0?
Im thinking of future engine work once it wears out a bit. Will there be 3.0 interchange parts that can improve the 2.7 that will be available in junk yards eventually? Im not expecting old school windsor like interchange, that had a similar block design for over 35 years. But it would be cool if heads, injectors, turbos, or cams were swapable even with machine shop help.
Rsimon
Ryan
Louisiana
I believe the Explorer has a 3.58:1 rear end. All I can say is my truck has the 6.2L with 4.30:1 gears it feels like a plug after driving the Explorer.
FirstOnRaceDay
Devin
Toledo Ohio
there are 2 different 3.0 aluminum and iron. BOTH are just bored AND stroked versions of the 2.7. But same basic block.
Iron block - Continental and MKZ 400hp and 400lbft
Aluminum block Explorer And aviator
365/380 or 400/415.
then the 3.0 power stroke is basically the 3.0 iron block but made for diesel.
Nickp
Nick
Phoenix
365/380 or 400/415.
Zero idea if it's true, but someone on Facebook for the Bronco 2021 group was talking about having an "Inside source" with the cad drawings. He said that the 2.7 will be an option, and the 3.0 will be the bronco raptor engine
He also said Coyote will not happen because it doesn't fit between the frame rails and would require modification of both the frame and suspension components.
Grain of salt etc. but very interesting.
MaverickMan
Shane
Well thats all interesting. Maybe in the future we can use the potentially diesel block or part of its 2 piece for a strengthened stroker with larger turbos. Could be wild. If there is that much common architecture im sure machinists will be more then happy to play around with all the junkyard f150s and such. Budget HP builds are always inspiring.
Spooled
Republic of Texas
The 3.0 Powerstroke and 2.7/3.0 Ecoboost are not related at all. The Lion diesel was co-developed with PSA Peugeot in Europe and has been in production in Europe since 2009.
Nickp
Nick
Phoenix
It’s pretty hard for me to imagine a bigger waste of money than buying a 3.0 powerstroke engine in any vehicle. Hence why they barely sell any of them.
FirstOnRaceDay
Devin
Toledo Ohio
It’s pretty hard for me to imagine a bigger waste of money than buying a 3.0 powerstroke engine in any vehicle. Hence why they barley sell any of them.
agreed. There is absolutely no point of small diesels in America other than bragging about driving a diesel... then you look like a tool as you make commercial trucks wait for the diesel pump as you fill up your Vw...... oh wait.
but anyway. The minimal torque and mpg gain vs a turbo gas engine isn’t worth the headache of maintenance and fuel costs.
MaverickMan
Shane
Oh scratch that someone said the block was the same, which in my head was, beefy mains form a gasser build. I dont know just dreaming here, before i was into offroading i was into hotrodding. And hotrodding at its core is making things work together to go as fast as you can cheap with what you can find laying around.
But 3.0 and 2.7 gassers parts interchange sounds promissing.
teejayhoward
CO
BRZ
It's not true.
If a DOHC V6 fits between the frame rails, it's wide enough for a V8. If an inline 4 fits, it's long enough for a V8. We know there's a turbo-four option, so if there's a V6 option then the Coyote will fit. If the Coyote won't fit due to frame rail issues, then there won't be a V6 option.
JimmyDean
Louisiana
It's not true.
hell, if I can fit a 460 into an 80s ranger (with the headers outside the frame rails) or a 460 into an 82 bronco with the headers inside the frame rails, you can get the coyote to fit, just require moving some other under the hood stuff, but there is a way.
as for suspension, that swap would likely also include an SFA swap, which removes all the suspension issues
Spooled
Republic of Texas
It's not true.
The 2.7 ecoboost is a 60* V, the Coyote is 90*. The Coyote is wider just considering that. The coyote wouldn't fit due to shock tower restrictions more likely than frame restrictions.
