3,220 lbs tow rating showing for certain trims / models
AcesandEights
Ace!
Oregon
DR650
  • Thread starter
  • Banned
  • #1
Looks like the recently release specs show lower than 3,500 tow ratings for certain trims.
4D, Badlands, 2.7/auto, 3,220 lbs. Might check your trim against the specs. 3,500 was the "max".
HotdogThud
mk6 gti, '21 MoarDoor
IIRC, it's not the vehicle itself, it's that certain trims because of the extra equipment, just simply weigh more, and the GVWR on the bronco is much lower than the Ranger. Which is obviously due to a ton of other factors, frame size, transmission, brakes, cooling, etc. it's just not made to tow big loads.
NoDoorsNoProblem
Aaron
Georgia
2016 GMC Canyon SLT Mini-Duramax
Was there a new spec sheet that got released along with the HP/TQ numbers? Do you have a link?
amccue90
Andrew
Illinois
2021 Badlands
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Oh man - that would have been the straw that broke the camels back after getting a look at the hitch receiver last week. Checked: 2.3L 7MT 2Dr Badlands is still at 3500.
I have to say, if you are planning on pulling an overland trailer, you'll need to be lighter than 3220 anyway if you don't replace the receiver with something more overbuilt. It's like they went the the bare minimum thing possible.
The Defender 90 and the Gladiator are way closer to my intended use. If the changes and delays keep up, I may yet bail for three years and wait to see if Ford gets things sorted.
2Jeeps&PatriotX1
Denver, CO
Well that was my plan for our overland trailer. Order the tow package on the 4dr BL, swap out the receiver and have the factory wiring in place to add the redarc brake controller.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Dads_bronze_bronco
Me too. Definitely swapping but want the 7pin wiring integration
Lakelife36
Ben
Interior of BC
We've had this information since January (ish) - providing it hasn't substantively changed since then.
Yes the tow rating is only lower on some higher trim (read higher curb weight) 4-doors, but those have similar - and in some cases even higher - GVWR than the Ranger does. It's the GCWR that is governing here, not the GVWR. GCWR. GCWR. GCWR.
Now since it's so "obvious" how about you tell the class how you know that each of those things you listed are governing the GCWR please.
All 2 doors are still 3500lb, only 4 doors are reduced lol
Yes. That's because the GCWR is the same between 2- and 4-door models of the same powertain configuration, and the 4-doors have higher curb weight. On lower trim models - both 2-door and 4-door - the tow caps are waaaaaaaaaay less than GCWR minus CW minus 300lbs. The silver lining is that you can actually carry quite a bit of payload while towing the max capacity. Also the "short wheelbase can't tow" crowd has conveniently gone silent, which is another huge bonus.
This has all been covered in previous threads on this forum. I've posted a spreadsheet that crunches the numbers for us multiple times on them.
