32's and 4.27 vs 33's and 4.46 - performance and MPG?
johndeerefarmer
'17 F150, '20 F350 Powerstroke
Any difference in performance (towing a RZR) or fuel economy
Outerbanks 32's and 4.27 vs
Badlands 33's and 4.46
or does the 1" taller 33" make them equal?
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S
Effective gearing is nearly identical; The bigger tires will cost a bit of mileage because of the greater rotational inertia but that is likely a fart in the wind with such a small change in size.
dgorsett
colorado
F250, Mustang, Explorer
Tire size is about 3% different, gears are about 4% different, close enough. With the Badlands you get the M210 (stronger) front diff and front locker, SBD and better off road tires. So if it's a coin toss for you get the Badlands.
johndeerefarmer
Thanks. I also like the looks of the Badlands so getting a better looking Bronco and better capabilities is a win. Only thing I like in the Badlands is the leather trimmed seats but will give that up for the better overall looks and performance of the Badlands...
dominicenoa
Dominic
Oregon
2021 Ford Bronco Badlands
This confuses me on which one you're getting lol, sounds like you're comparing Badlands to Badlands now
johndeerefarmer
Sorry only thing I like about the Outerbanks is the leather seats but I prefer the Badlands for looks and upgraded drivetrain
timhood
Tim
Several
You can get leather in Badlands if you want.
johndeerefarmer
Sorry I should have specified I like the two tone leather on the Outerbanks. For the Badlands I would rather have vinyl and apply that money towards the High package
HoosierDaddy
Indiana
Not even an inch difference in actual tire size ....32.1" vs 32.6".
Need to run the two set ups on grimmjeeper.coms gearing comparison tool.
mpeugeot
You'll see some difference in fuel economy (especially above 60 MPH due to the increased frontal area - but not a huge difference - maybe 1 mpg is my guess). You'll certainly see some change in performance due to the fact that the rotational mass will increase 20# per corner, which will have an impact on acceleration (assuming the A/T Duellers are 40# and most M/T tires in 33" are near 60#).
Gearing, however, really isn't a factor.
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
if i am not mistaken, the 4.27 is the standard autmatic trans gear set and the 4.46 is the manual trans ratio. with the 4.70 gear ratio reserved for the sasquatch / 35 inch tire options.
johndeerefarmer
Build and price for a Badlands with the 2.7 and 10 speed auto show 4.46 is included. 4.70 is optional with SAS. Manual tranny gives you 4.7 as the only option
Outerbanks is 3.73 open diff is standard, 4.27 is optional. 4.7 comes with the manual
johndeerefarmer
32.1" tire and 3.73 gives you:
70 mph is 1749 rpm
80 mph is 1999 rpm
32.1" tire and 4.27 gives you:
70 mph is 2002 rpm
80 mph is 2288 rpm
32.6" and 4.46 gives you
@ 70mph is 2059 rpm
@ 80 rpm is 2354 rpm
On Edit: I used the 10r80 ratios instead of the 10r60 but they are close enough...
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
3.73 - Standard auto
4.27 - Optional on OB and BB auto
4.46 - Standard Manual, standard on BD and BL auto
4.70 - Standard BL manual and Sasquatch Auto
