35s on Non-Sasquatch Badlands
LowerDixie77
Alabama
1977 Bronco, 2009 F150, 2017 F150
I’m probably going 35s at some point in my Badlands but I’m going to wait till the tires are worn. If fuel cost don’t come down I’ll keep the 33s
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Good call. The mileage hit sucked for me, I kind of wished I just swapped the KO2s onto the new wheels. The stock wheels had to go through, I hated them.
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
315/70/17 hits METAL fender in my NON sasquatch Badlands when flexed hard. I hear and see full contact when offroading. I have the RC level kit to go on. I think it will eliminate the rub. I take the fenders off because the tire would rip them off when wheeling hard.
braften
st louis mo
2022 Bronco. goodbye accord, you served well
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
Any pictures of contact when flexed?
braften
st louis mo
Tricky Dick
Dick
PNW
nice, and not too much poke then?
A little more than I prefer, about an 1" of tread and another 1" of sidewall. Thinking about getting sasquatch flares, they would be almost flush.
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
I pulled my wheel spacers last night. 3/4” clearance to Upper control arm.
badlands et55 wheels. Bead locked at 8.5-8.75 wide.
Drives so much better without the extra offset, I didn’t like how it tracked or handled with all the width. I really feel like it trashed the Ackerman or some other angle. The center of steering almost felt like it had 1/4 inch of dead space with the spacers on. It followed road deviations more with that extra 3” of width.
still need to get the RC level kit installed. Hopefully in the next week I have time.
steverollin
Houston
2dr Badlands, BMW X7, LX 570, TRX on order
Trying to find a good thread to ask this without starting a new one.
Has anyone put 35x12.5 on the STOCK badlands wheels on a non-squatch model? I may be the only person that likes the stock wheels. I have been considering:
Stock badlands wheels
Small wheel spacers to square things up better
35x12.5 hybrid tire of some sort (aka a truish 35 ... not a KO2 type 35)
Remove crash bars
MAYBE a small level kit, again just for looks and a tad more space.
Anyone running this? I'm pretty sure it will work, maybe rub when disconnected, which I'm not stressing. I prob won't wheel this. Keeping the jeep.
I may run this a bit and then if I get bored of the look, go aftermarket wheels and ditch the wheel spacers of course.
Now if anyone has a picture of this on a 2 door Carbonized Gray, you'll just be my hero
BroncoAZ
Mitch
Remove crash bars
You could go with a narrower tire like the 35x10.5R17 Kenda or 35x11.5R17 Toyo and I think you’d be fine. @LHD is running the Kendas on +35mm wheels on his base.
https://www.bronco6g.com/forum/threads/will-35s-fit-my-base-bronco.38460/#post-1255978
I’d just rip the band aid off and get aftermarket wheels now.
Pilsner
JTR, 81 Bronco, 21 BD
Lift does not fix rubbing. Unless you change geometry or bump stops, the suspension cycle is the same.
