Bronco-Israel
Israel
4x4
I tried it both ways connected & disconnected. There is no rub either way. The only run is when you try to do a U turn. I think that if the tires were 37x12,50 there would not be any rub at all.
12.5 is the way to go + 1” leveling kit
Lobber
Ray
Kansas
I put Goodyear 37x12.5x17 MTR's on mine with the same setup and mine rubbed in the same spot. I'm currently doing some cutting and welding to make some room.
MWILD
2022 - BB Sasquatch - Mid - 2.7L
Do you have plans to install a lift or leveling kit? Also, pictures? 😁
Lobber
Ray
Kansas
It's has a 1" RC leveling kit on it, I'm considering going higher but I want to wait and see what else comes out in the next year.
donivan
Houston
Mercedes GL63
37x13.50r17 Toyo M/T
I don't think it was mentioned but these 37x13.5R17 are actually 37.0x14.6 per Toyo specs. These are true 37s and very WIDE tires! Not sure why they don't list them as 14.5" wide? The Toyo MT 37.0x12.5R17 spec out at 36.8x12.5. Either way great looking ride and if you can fit these 37s you should be able to fit any 37 out there.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
If you have ever seen them side by side , you can see how much bigger they are......
Deleted member 12876
Guest
This looks awesome! Could it use a slight lift? Sure. But it’s still amazing that a Bronco with Sasquatch can fit 37s without any modification. If they don’t rub while turning, I’ll be even more impressed!
They’ll rub when wheeling though
Gtrekker
Gary
NJ
The Toyo are a closer true 37". I run 37" K02s with no lift, no levelers, no rub. OEM WT wheels
K02s are closer to 36.5"
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
So a 2.5" lift and going from 35s to 37s should only increase my overall height by 4.5 inches?? Gotta make sure it still fits in the garage and only have about 6 inches to play with 😁
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
No 3.5”.
