EvlNvrDys
Hunterdon County, NJ
She looks nice... Can the little 2.7l turbo spin those tires? Or was it a 2.3? I didn't bother to look.
AK SNO RIDER
Ty
Alaska
'17 RS, '04 6.0, '76 High Boy
as a side question, has anyone heard complaints about the 2 pc lug nuts Ford is using on the Ranger and the Bronco? Are you guys changing the lugs nuts when installing the custom wheels? if yes what are you getting?
Ford uses them on everything and they are cheap fucking trash. Worth it to swap them out if you will be removing tires even semi-regularly.
And it's common to need or use different lug nuts when switching to an aftermarket wheel.
vrtical
Doug
TN
Fords
Looks like it will be maxed out on a parking curb
bytheway
bytheway
Brice
Louisville, KY
2003 Toyota 4Runner
He said they do rub when turning lock-to-lock.
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Definitely looks good, but almost certain to rub. There's a difference between 'looks like it fits' and 'actually fits for use'.
As others mentioned on FB, good for mall crawling and looks. Less so for actually taking it off road.
Also curious if they bothered to have the speedometer and other computerized bits recalibrated for 37s, or if they never got past the 'need big tire look' phase of thinking.
jaruss01
NJ
2020 S60 T6 AWD / 2018 Subaru Outback Limited
I could see how you'd be fine with 37x12.5 over 35x12.5, but if these are 37x13.5 (which they look to be), they probably just cleared the steering knuckle, but I cant imagine that these wouldnt occasionally rub under moderately aggressive driving. The sasquatch only has 1.4" of lift. Imagine putting this tire on a non-sas with only a 1.4" lift kit?....you wouldnt...
Dom
Dom
Shamokin Dam PA
2000 Ford Expedition, 2013 Ford Fusion
They look way too stuffed in there. That's going to cause issues for sure.
Monster1926
Indiana
GMC Sierra 2500HD
2 piece?
Tricky Dick
PNW
Holy crap those 37s look 4" taller than the 35s
bytheway
bytheway
Brice
Louisville, KY
2003 Toyota 4Runner
Advertisement
4 Wheel Parts
Advertisement
