37" KO2s tire pressure
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Anyone running 37" KO2s, what tire pressure are you running? I used the tire pressure calculater and it came back with 32psi. I just want to see what everyone else is running. I also did chalk test after setting it to 32psi and i'm getting full contact. It just seems low to me. Thanks.
Deleted User 5719102
Who's
On a Lake
22 2dr
I run Mickey Thompson's 37's and I run them at 37psi. I even reprogrammed my TPMS sensors for 37psi.
jzweedyk
Moab, UT
Lincoln Aviator
Picking up my Badlands next Monday, and I plan on running 37 KO2s (after mods). 32 seems right to me. On my 19 Raptor with 35 KO2s ("C" range), I ran 32, and it is a heavier truck. Did you get the "C" range 37? If so, it should be good, if you got the "E" range 37s, then I might go lower.
My 2 cents, which might be too much.
ICUGAZN
ICUGAZN
Kevin
2019 Raptor
Yes, I have C range. Thanks.
