Was thinking of keeping the stock wheels for nowI'm going to be running Gladiator XComp A/Ts with a 13.5 width... It all really just depends on your wheel offset that you end up selecting.
Do you have the sasquatch package at least? I'm going to go out on a limb and say if you're using factory sasquatch setup, you'll likely want to stick with 12.5s... but I'm not positive.Was thinking of keeping the stock wheels for now
Yes I’m squatched.Do you have the sasquatch package at least? I'm going to go out on a limb and say if you're using factory sasquatch setup, you'll likely want to stick with 12.5s... but I'm not positive.
Really depends on brand of tire , as some manufactures are not true to size in sizing charts - some 13.5 come in over 14.5 wide - depends on offset -for reference i use 12.5 toyo mt with 0 offset and slightly slightly kisses the removed crash bar win turning is maxed out.Yes I’m squatched.
I’m looking at Nittos. Ridge grapplers I believeReally depends on brand of tire , as some manufactures are not true to size in sizing charts - some 13.5 come in over 14.5 wide - depends on offset -for reference i use 12.5 toyo mt with 0 offset and slightly slightly kisses the removed crash bar win turning is maxed out.
