37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Now before I go into the 1in spacers. I have 2000 miles on the 1/4in spacers looks to have no new rubbing and Look close and you can see a little paint off of the end of that one bracket. no marks on the backside of the tire also.
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8515
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8516
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8517
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Sway-bar was disconnected
Ok the 1in spacer sucked lets talk numbers
35 offset 1in spacer/25.4mm with 1in spacer is 9.6 offset
35 offset 1/4 spacer/6.35mm with 1/4in spacer 28.65 offset
I will get some pics with the 1/4in spacer but it just looks a little better than the original pics.
Poke with 1in
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8518
Poke with 1/4in
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8519
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8522-1
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8523
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8525
Now I understand why people say the tire is hitting the rock rail. Due to poke.
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8526
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
I will try and get pics tomorrow of the 1/4in spacers in the same place as the 1in were tested in.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
This is same place 1/4 spacer sway-bar disconnected everything same as above.
As you can see much more room
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8529
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8530
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8531
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8532
Grodyoffroad
Pedro
El Paso Tx
76 Bronco, 21 FE, 22 BL
want to see more pics with the 1" spacers.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
I'll sell them to you but not putting them back on. For a non lifted Bronco Sasquatch on 37s its useless.
I showed it at max thats what I'm looking at for my use. Keep in mind this is also with sway-bar disconnected its a big difference for people that don't have sway-bar disconnect.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Napa air compressor
https://www.napaonline.com/en/p/BK_MTWM10215C?impressionRank=1
Watch this video and yes I aired mine down and its this fast even with 37s like stupid fast.
Parts list
https://www.amazon.com/gp/product/B07DW6HRSX/ref=ox_sc_act_title_1?smid=A3J5E5ZOT6VBB2&psc=1
https://www.amazon.com/gp/product/B08BTPG6J8/ref=ox_sc_act_title_2?smid=A71CK5ZVE8V5E&psc=1
https://www.amazon.com/gp/product/B08ZY89XPT/ref=ox_sc_act_title_3?smid=A3JAEDBVGJT059&psc=1
https://www.amazon.com/gp/product/B074VDXRYX/ref=ox_sc_act_title_4?smid=AV2QYO3V8OV1I&psc=1
2 of these
https://www.amazon.com/gp/product/B00DE89ZYM/ref=ox_sc_act_title_5?smid=ATVPDKIKX0DER&psc=1
https://www.amazon.com/gp/product/B084ZVBMCR/ref=ox_sc_act_title_6?smid=A1U0GG705VIV5P&psc=1
https://www.amazon.com/gp/product/B082KRLRM7/ref=ox_sc_act_title_7?smid=A1AOZNO078ITBS&psc=1
Will use these to air down (This worked great and is priced right)
https://www.amazon.com/gp/product/B07TTGFTJK/ref=ox_sc_act_title_8?smid=AQQYAJZHKJVLN&psc=1
So I decided to only do one line and use the line that came with the compressor. I left the original connector add added my connector back a ways the reason I added it back so far was heat didn't want to need clamps so made sure the hose was cool in the place I added the connectors. As you can see from my parts list I added enough to make two lines but its so fast I decided to only make one and it made it so it all fit in the compressor bag even the air down fittings fit in the bag.
As you can see in pics I took out the air gauge and added my own 1-20 and 20-120. I see me adding a tire patch kit it this bag also.
The idea is when I get ready to go rock crawling I can just pick the bag up and I'm ready to go. Quick and easy and wayyyyyy cheaper.
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8672
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8673
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8635
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8636
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8637
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8638-1
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8640
Ford Bronco 37x12.5r17 KM3s Sasquatch Badlands No Lift/Build Thread IMG_8641
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Napa air compressor
Parts list
2 of these
Holy crap, the NAPA air compressor kicked the shit out of that overpriced ARB. Good video find.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
bcl0404
Brendan
New England
2017 F350
@Bradley, just wanting to give you credit here: I think this is one of the cleanest, best looking set-ups I've seen! (y)
Still patiently waiting for delivery of my Bronco, but I'm making plans for similar modifications to what you've shared here.
I have a few questions if you don't mind:
1) I have a 4dr Black Diamond Sasquatch on order. Does your Badlands+Sasquatch have more lift than the BDSquatch?
2) If the BadSquatch and BDSquatch have the same lift geometry, it looks like your 1/4 inch wheel spacer provided the best fitment to reduce rubbing. Would you say that you're completely clear of rubbing now at full-flex with the 1/4 inch wheel spacers? My BDSquatch will not have the swaybar disconnect - will my lack of swaybar disconnect help to eliminate any rubbing if I implement the 1/4 inch wheel spacers?
3) If you're still rubbing anywhere with your current set-up (incl. the 1/4 inch wheel spacers), would a 1 inch Zone level or 1 inch perch collar level completely eliminate rubbing? Or is a level not necessary?
My plan would be to run 37x12.5r17 AT tires like I currently run on my F350 as I daily drive, so not looking for a super aggressive height or section width 37 as I'd want this to fit with practically no rubbing.
4) Would any size wider wheel spacer fit (e.g. 1/2 inch), or would it rub, and where? I saw your comment that the 1 inch wheel spacers did not fit well. I will have the OEM rock rails on my BD.
Apologies in advance if any of this is already covered elsewhere and thanks for your help.
Again, nice work (y)
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Thanks
1. No (Same)
2. Yes, 1/4 best fitment with Sasquatch stock wheels. Yes, I have pics showing with and without swaybar disconnected. Without has way more clearance.
3. You will have no rubbing with 1/4 spacer. This is a trick question with the tire I have KM3s or KO2s you would be fine and have no rub being they are only 36.4in but if you get a true 37in tire I THINK you want rub but can't promise being I don't have it. My opinion is unless you want the lift try without if it does rub it will be soooo small it won't hurt anything and you can just add 1in zone leveling kit. If you want it leveled anyway do it it definitely won't hurt a thing.
Your plans won't be a problem but I personally think the 1/4 spacer will be needed but thats all.
4. As I said before in my thread 1/2in spacer won't work unless you are willing to add longer studs. Now if you change wheels you can get that spacing I'm sure but from my testing 1/4in spacer looked to be the sweet spot. (My opinion) You can look at pics with 1/4in spacer and then 1in spacer and see what you think but that my opinion. @1in you can see it starts getting into the fender under full load and swaybar disconnected.
