38x13.5r17 Patagonia M/T Sasquatch Badlands 2in Lift/Build Thread Round 2
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 98 Jeep, 92 GT, 93 Cobra
Rear spacers are on. Found a battle scare from Windrock. Will have guards ordered.
Working on front now. Will do more write up later.
Advertisement
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
So I talked to Zone lift yesterday
Front Spacer adds 1 3/8 lift, Spring Perch adds 5/8s
Rear spacer adds 1in
Reason I called them was the rear spacer was 1 1/2in thick. So as many of you know normally that adds 1 to 1 on a solid axle but they said due to the shock being at an angle it didn't.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Will post more pics today when done.
One thing I would like to point out that I didn't know and really couldn't find in a video. ((((You have to use a spring compressor to turn the top cap 180deg this is a must if you have the Sasquatch due to the reservoir on the shock. Make sure you mark before moving so you know where 180deg is))))
Spring compressor I used. Front was much harder to compress than the rear.
https://www.harborfreight.com/singl..._ebm4ycZfU3B_IPZsWjQlRAM1Fce_CxYaAi2QEALw_wcB
I am doing the lower A-Arm removal I have the Badlands so it was a little more to it then this video but not hard.
Key thing is the hydro disconnect what I did and it was easy is just undo like 4 plastic clips and unplug from the main harness on the frame. Its like 8 15mm bolts and it comes right out. ((Will post a pic of location later))
Being I wasn't adding the spring perch I used the instructions for the regular 2in leveling kit and not the Sasquatch. But I bought the Sasquatch kit incase I wanted the add the spacer or spring Perch later.
https://zoneoffroad.com/search?fitment=1
This is another video the one will explain how to add spring perch. If you're doing that.
Lurker B6G
Murph
Cleveland, OH
Ford Explorer Timberline
FOLLOWING, BUT...
I am calling shenanigans on them (Zone). :unsure:
I may not be the smartest cookie in the jar, but I am OK at math.
1.5 inches resulting in 1 inch of lift would mean the ratio is 1.0/1.5 = 0.67
sin-1(0.667) = 41.8 degrees from the HORIZONTAL!
This is nonsence. When the shock orientation is anywhere near vertical, the acual angle is completly negligible.
Lets say the shock is angled 15 degrees from vertical. Sin(75) = 0.97.
1.5 x 0.97 = 1.46 (you couldn't even measure 0.04"!).
Now lets say the shock is angled 25 degrees from vertical (that's a lot). Sin(65) = 0.91.
1.5 x 0.91 = 1.36 (most likely would not notice an eighth of an inch).
The only reason that the ratio is like this in the front (but reverse) where 1.0 inches results in 1.5 inches of lift, is because the shock is mounted 1/3 of the way inwards towards the pivot point (no trigonometry needed). Therefore all action on the outside is 50% greater than at the shock mount.
But, the rear the shock mounts almost directly below the axel (on a bracket). It would need to be mounted a HUGE distance behind the rear axel (half of the trailing arm length) for there to be a fractional ratio like they are proposing.
By all means measure the acual effect of the rear lift. I will be shocked (pun intended) if it is outside of a 0.95 to 1.05 ratio to the actual part thickness. However, I would be interested to know since I will be doing the same thing if I get a build.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Advertisement
Merc4x4
steve
NYC
I set the alignment back stock and this is how far it was out.
Looks great! Tires look huge.
Love the dichotomy of the tube doors and pouring rain in your pic!
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Me and the Good Lord tight so I asked him if I rode up to Ford would he make the alignment machine be free being I knew it was about to rain he said roll with it. Made it just in time no joke it stopped raining seconds after they got done. Yes, I gave him all the glory. Yes, that’s a true story.
cgv
Apex, NC
Bronco Badsquatch, Explorer ST
Looking good!
Why did you leave out the perch spacer? Also, did you install the bumpstop extension?
BTW, I think the Icon 3" lift video/instructions shows that you can disconnect just one side of the sway bar and push it far enough aft to get access to the LCA bolts.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Looking good!
No perch spacer or bumpstop.
Reason I’m a less is better. But also the perch spring would have hurt the ride quality. I left the factory bumpstop I will add the bigger if I need too. This is a toy to me so I will see if this will work with the 38s if not I will probably add a bigger spacer but not sure I will add the perch spacer.
if you would post the video on my page for the next guy.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
This thing looks stupid good but no testing yet.
cool fact to the top of the finder in the center on the front is 42in rear is 42 1/2in
Advertisement
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
In my old build I have this pic of before I’m on my phone but will add it later
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Interesting it was 11 1/2 drop before I put the sway bar when I added it it was only 11in (((this is just put on like installed on the lift not turned on)))
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Few pics of how I got the A-Arm back on the main one that really matters is the 2x6 one. The second A-Arm went very fast after I had done it once.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
See Post #56. (((This is the old pics with the KM3s 37x12.5r17s no lift))) So I gained 3in total.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
Took a measurement at the lowest spot on the front going left to right it’s that first hump and it was 16in
Advertisement
