What are the pros and cons to both? Which should I prefer on 2.3l auto
The two most common reasons you might consider upgrading to 4.7:What are the pros and cons to both? Which should I prefer on 2.3l auto
ItWhat are the pros and cons to both? Which should I prefer on 2.3l auto
The new 2022 B&P no longer shows this as a price increase. Not sure if it is correct, but it is now a choice. Not sure which one has 5% more engine revolutions, but is one more efficient at highway speeds?`5% more engine revolutions for each wheel revolution. So a `5% increase in torque for 5% more wear and tear or tiny bit of worse MPG. They are nearly identical, not worth the cost to change from one to the other at all.
If you search on youtube for town & country ford, mitch from that dealership has a badlands non-sasquatch which they put a lift and coilovers with 37" tires. He had some rubbing, but I think that was mentioned could be fixed with some adjustments on the coilovers.Thank you. I was trying to figure out why someone wouldnāt go ahead and take the upgrade for free especially with 10 speeds. I would think mph would still be good. I do plan on going to atleast 35s, preferably 37s if I can get it lifted high enough affordably. Iām non sas due to constraints and needing it sooner than later. How high do I have to go to fit 37s and can I do it without new coil overs?
Compared to 32s that are standard?, 2.5" (half the difference in diameter, the otehr half is below axle centerline)Thank you. I was trying to figure out why someone wouldnāt go ahead and take the upgrade for free especially with 10 speeds. I would think mph would still be good. I do plan on going to atleast 35s, preferably 37s if I can get it lifted high enough affordably. Iām non sas due to constraints and needing it sooner than later. How high do I have to go to fit 37s and can I do it without new coil overs?
