4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories!
Status
Not open for further replies.
Sinister CNC
NM
Ram TRX
The 4Quarter20 Dash Rail is our newest and most effective way to connect up to four of your favorite Bronco accessories! Our 4Quarter20 rail is just that, four 1/4-20 mounting locations right from the single point accessory mount found on the dash of the Bronco. Our rail allows you to use any combination of 1/4-inch studs or nuts to connect your favorite mounts and accessories. Simply flip our rail over and install a bolt or a nut in any of the four mounting locations on the rail to match the corresponding accessory or mount you want to run. Our 4Quarter20 Dash Rail kit comes with four 1/4-20 bolts, four 1/4-20 nuts, two 20mm ball mounts, and our one-of-a-kind Quarter20mm vent mount! This unique mount is dual-sided, allowing you to use most vent mount phone holders from the rail itself, or flip it around to use the ball mount to attach a 20mm mount arm!
Now available: https://www.etsy.com/shop/SinisterSpeedShop
$100 shipped to your door with free express shipping!
*New 4Quarter20 Dash Rail Kit - Basic*
Our newest dash rail kit is the easiest and most affordable way to mount multiple 20mm accessory arms to the dash of your Bronco! This kit also includes two rubber accessory arm supports that we developed to help keep all your accessories solidly in place along your dash. Say no to floppy arms and wobbly accessories with this kit!
https://www.etsy.com/listing/1202780048/bronco-dash-mount-accessory-rail?click_key=d9dad279d3a0d336c17dd67be040e9173304cacf:1202780048&click_sum=627f3808&ref=shop_home_feat_4&frs=1&sts=1
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG_0593
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG_0598
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG_0594
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG-8189
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG-8190
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG_0588
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG_0603
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG_0605
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! IMG_0606
Kevin W
usa
AMB 4dr Sasq Base and an Erup Green 2dr Sasq Base
How much and where can I order one?
Sinister CNC
Sinister CNC
NM
Ram TRX
We are still trying to finalize pricing, but it should be $100 or less with all the mounts listed above. I'm just waiting on fasters to come so I can double check tolerances and start production. I'm hoping to be shipping these by early next week.
Garemlin
Delaware
Nice you are using 20mm balls. makes it compatible with Bulletpoint and 67Designs.
Smheard
Sean
Jenks, Oklahoma
‘19 Raptor, ‘21 Macan S, ‘22 Big Bend, '21 FE
I would say yes since that’s a 67 designs carbon fiber arm in the pic.
Garemlin
Delaware
LOL That's exactly what I said. It's nice they are using 20mm balls which are compatible with those two. And it's probably a Bulletpoint arm since it is Bulletpoint phone mount.
Sinister CNC
Sinister CNC
NM
Ram TRX
You guys are spot on! My 67 Design arms should be here by the weekend and I can't wait to get them mounted to this rail! I was so stoked on this new rail that I couldn't wait for them to come in before announcing it.
The amount of accessories and mounts is dizzying, but we are doing our best to distill it down to the best solution possible. With this rail we are aiming to have the lowest profile possible, simple installation with no drilling, flexibility to adapt as many accessories possible, and also include the most used mounts to help reduce the time and cost associated with sourcing various adaptors and mounts.
Sinister CNC
Sinister CNC
NM
Ram TRX
Our new favorite mounting location using our 20mm vent mount with a Belkin MagSafe iPhone holder. Our vent mount rests on the dash nicely and adds extra stability. We are also including a rubber base for our vent mount so that it has a xtra grip on the dash. Super low, solid and easy to see and reach. 😎
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! BF4B2632-C605-4559-BE87-B303ECE919F1
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! 26E399CE-591A-448F-BC86-5FC7A1A8C848
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! E1B789BB-0D3A-41DF-8AAE-6A716D8F1CB7
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! D8D72470-D847-4647-A7BF-F3D9D8D1A822
fv9
Camas, WA
2018 Alfa Romeo Giulia Ti Sport, 2005 Lotus Elise, Protoform P3 formula vee, Crossle 32F formula ford
My Bronco isn’t here yet to see if it would work, but a way to attach a mag safe charger mount would be awesome. Right now it’s clipped to my current vehicle’s vent. Would love something like this serving the same purpose in a cleaner fashion.
Sinister CNC
Sinister CNC
NM
Ram TRX
The spring-loaded phone holders are great, but for daily use the magnetic holders are definitely the way to go. The new MagSafe holders are really good too! No need for adding that extra little piece of metal under your phone cover.
fv9
Camas, WA
Agreed. Find a way to connect one and power it (run the USB cable though a hollow extension arm maybe) and Im in.
Sinister CNC
Sinister CNC
NM
Ram TRX
I like that idea!
  • Like
Reactions: fv9
Ironiguana
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! 08F97350-989A-4A5F-A1A6-6F3124A7BA91
What length of the 67 arm works best? Thanks.
Status
