4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories!
Status
Not open for further replies.
Sinister CNC
Sinister CNC
NM
Ram TRX
What length of the 67 arm works best? Thanks.
In these photos I have the Belkin MagSafe mount on a 7cm (5.9-inch overall) arm from Bulletpoint Mounting Solutions. It looks like the equivalent arm from 67 Designs would be their small arm which measures 6.5-inches long.
calcutta
Coby
La Quinta, CA
2021 MME CA Route 1
Received today, installed tonight with the Belkin magsafe mount; exactly what I need! Thanks a ton! Excited to mount a camera and get some nice trail footage 🤩
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! 0C1D8493-C9EE-48EC-831E-02A39E38E329
Sinister CNC
Sinister CNC
NM
Ram TRX
Looks great! Thank you for your order and I hope it serves you well for a long time to come!
Sinister CNC
Sinister CNC
NM
Ram TRX
We’ve got the family loaded up for a little road trip and our mount is working out great for everyone! 😎
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! 55DEB6C1-968A-4A3A-A39E-D54EC8D3079E
Gamecock
Does Belkin make a MagSafe mount that attaches to a 20mm ball? I only see the one that attaches to a vent, so you have to put something else between a rod and the mount?
Diamond_Dogs23
NJ
Honda
I have ordered one as well and am wondering what the shortest arm length will work with the mount so it doesn't hang over the dash or block the hero switches? I see in the photo you are using the ones around 6 inches long and looking for something shorter. Thanks
Sinister CNC
Sinister CNC
NM
Ram TRX
I've made a custom vent mount that is included with my dash rail kit that will adapt any vent mount phone holder to a 20mm ball. I used the Belkin MagSafe to model my design from.
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! tempImagey85KJT
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! tempImagef71eyu
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! tempImageFFQUwa
Sinister CNC
Sinister CNC
NM
Ram TRX
The good thing about the 6-inch arms is you can angle them nicely to ago around the hero switches. I don't have a shorter arm than the 6-inch currently. On the passenger side side I'm using a 7.8-inch arm and it works with our vent mount nicely.
Sinister CNC
Sinister CNC
NM
Ram TRX
Are those 3D printed?
Yes, our kit is made with an engineering grade PC reinforced with Carbon Fiber. It matches well with the interior of Bronco. All of our hardware is black (prototype photo below without final fasteners) and uses Torx fasters to match the Bronco hardware as best we could.
Ford Bronco 4Quarter20 Dash Rail - The Simple Solution For All Your Bronco Accessories! 3D276FFB-EF57-4623-ABC9-9411BB3EB281
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Markforged printer I am guessing?
@BadBlueBronco
Kc
Los angeles
The base is likely Ok but I’d caution you on the other mounts. They may not be critical if they break but these ball mounts will definitely see premature wear fyi.
Sinister CNC
Sinister CNC
NM
Ram TRX
To be extra extra safe the ball mounts have a 1/4-20 bolt through the middle of them so they are basically a big flat head bolt to reduce any risk of breakage.
@BadBlueBronco
Kc
Los angeles
That helps on the weak portion to keep it from snapping but my concern would lie with the build lines. Those build lines will wear prematurely and scar with years of use. Have you thought about selling the mount alone and letting people purchase cnc ball mounts?
Status
