Sorry I missed adding those in the last post! They are the Belkin Car Vent Mount PRO with MagSafe.^^Thank you. Which device holders?
How does this mount attach to the Bullet Point arm?Sorry I missed adding those in the last post! They are the Belkin Car Vent Mount PRO with MagSafe.
https://www.belkin.com/us/magsafe-m...e/car-vent-mount-pro-with-magsafe/p/p-wic002/
You have all the toys.... Do you use your phone to record the trail ride and did you link it to the Ford app?The 4Quarter20 Dash Rail is our newest and most effective way to connect up to four of your favorite Bronco accessories! Our 4Quarter20 rail is just that, four 1/4-20 mounting locations right from the single point accessory mount found on the dash of the Bronco. Our rail allows you to use any combination of 1/4-inch studs or nuts to connect your favorite mounts and accessories. Simply flip our rail over and install a bolt or a nut in any of the four mounting locations on the rail to match the corresponding accessory or mount you want to run. Our 4Quarter20 Dash Rail kit comes with four 1/4-20 bolts, four 1/4-20 nuts, two 20mm ball mounts, and our one-of-a-kind Quarter20mm vent mount! This unique mount is dual-sided, allowing you to use most vent mount phone holders from the rail itself, or flip it around to use the ball mount to attach a 20mm mount arm!
Now available: https://www.etsy.com/shop/BroncoForumShop
$100 shipped to your door with free express shipping!
I designed and made a custom "vent mount" with a 20mm ball on the back of it. This way you can connect it to a 20mm mounting arm and rest the vent mount adaptor on the dash for a super solid mounting location. Our vent mount adaptor also comes with a rubber base so that it rests on the dash well and doesn't rub. Our vent mount adaptor also screws into the rail via a 1/4-20 nut in the base if you want to run vent mount accessories without an arm.How does this mount attach to the Bullet Point arm?
I have used my phone to record trail rides because it's already in a great location and quick and easy to pull up the camera/video. I haven't linked to the Ford app yet, but I need to do that!You have all the toys.... Do you use your phone to record the trail ride and did you link it to the Ford app?
Nice, thanks. I'm going to set up my GoPro 360 on the back / top of the MIC. Interested how it will turn out.I have used my phone to record trail rides because it's already in a great location and quick and easy to pull up the camera/video. I haven't linked to the Ford app yet, but I need to do that!
I have a rear GoPro solution that I've been playing around with. I will let you know when I finish up the prototype.Nice, thanks. I'm going to set up my GoPro 360 on the back / top of the MIC. Interested how it will turn out.
Is this the mount you are referring to?Would this work with the Peak Design mobile mount?
yes. I emailed them to ask the size of the ball connection, but haven’t heard back yet.Is this the mount you are referring to?
https://www.peakdesign.com/collections/mobile/products/car-mount
Let me know what they say. I'm not familiar with that mount so I'm not sure what size it is either.yes. I emailed them to ask the size of the ball connection, but haven’t heard back yet.
Dang, I was hoping it was going to be 20mm so that you could use any of the standard accessory arms with it.They emailed back and said that the Peak Design ball is 15mm.
