5" lift, 37" nittos, highway speed is scary.....
Backwater
2020 GMC duramax
Just got the RC 5" lift, and 37" nittos installed on my OBX. When driving at highway speeds (70-80mph) the vehicle is very unstable. If I hit a pothole, semi rut, patch, etc. in the road, I better have both hands on the wheel or else it gets very squirrelly. Not quite a death wobble, but it's close.
Has anyone else had this issue? Any solutions?
Lilhoss105
Courtland
Dallas
MIC, Carbon Grey, High
SO... Kinda related/unrelated, but here I go.
On my ram 1500 2014 I put some aftermarket wheels and a bit of oversized tires and experience somewhat of the same thing at speed (65+).
I found that the wheels don't sit flush with the hub and the bore sizes are different. In lehmans terms the inside of your wheel isn't touching the hub and is "centered" just by the bolts. At lower speeds this isn't an issue. I would google bore hub for bronco and whatever wheels you have and purchase the hub centric rings (linked in the bottom). I havent installed mine yet, just found out this was the fix this weekend. So I will be installing and will check back asap.
Bronco hub size is 93.1mm you will be looking for ~~110 to 93.1 sizing.
***This is all assuming alignment, balance is all correct***
GOOD LUCK
https://www.amazon.com/dp/B08CXRYRQP?ref=ppx_yo2ov_dt_b_product_details&th=1
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Tire pressure should be lower than OEM. (Like a lb or two lower than a OBX Squatch.) Chalk test is the best way to find the right pressure.
Check balance and alignment. Make sure your wheel hub is the correct bore for the bronco or add hub centric rings.
5” lift? Was there a diff drop and UCAs in that 5” lift in front?
In back we’re the longer / adjustable control arms? Was there a longer / adjustable trackbar and / or track bar bracket?
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Was an alignment done?
Backwater
2020 GMC duramax
Diff drop, yes. No UCA’s because this is a knuckle type lift. Keeps OEM geometry. Yes track bar relocation bracket.
Cl1ckst3r
Joshua
Minneapolis
Ford Focus ST
I've got the Rough Country 3.5 with 37's and it rides fine. I actually don't know if I have even gone 80MPH but definitely 75MPH or so. I'm on 37x12.5R17 Fuel Rebel.
@Yetibronco21 I am sure there are several people on Bronco6G with a 5 inch lift.
Have you reached out to Rough Country?
