567 miles/10 days in, door wearing through rubberized strip down to metal
guerro
AZ
2023 Bronco Raptor
New issue of the day for me!
I noticed today that an element of the driver’s door has rubbed through a rubberized metal strip around the window that is attached to the body. It’s somewhat hard to photograph but I’ve done my best:
Looks like something acute is hitting in that exact point. What does the mating item on the door look like? I am thinking something raised is hitting the weather stripping.
guerro
AZ
2023 Bronco Raptor
I wonder if, when the window closes the rest of the way after closing the door, it is pushing too hard against the seal?
NotApplicable
BEVs
It is sort of raised; the whole edge of that rubber triangle is raised and rubs by / seats under the rubberized metal trim. There is a channel inside the rubberized metal trim and it appears as though it was specifically designed for the raised rubber edge of the triangle to fit under.
Inspection of the passenger side looks the same, but no current wear-through issue
The window does raise to seal/push against rubber lining the edge of the triangle here after the door has closed, though this is also the same on the passenger side. But, I’ve gotten the driver’s side more than any passengers have over the past 10 days.
Funkdoobiest
Buffalo
Ford Bronco Basesquanch First Edition
Show us the part that is causing the rub.
Newraptor
Lexus , Ford f150
I looked it’s the door rubbing.
Wanted33
Down south in Dixie
My hats off to those that have gone before us. It seems the "test subjects" are coming up with some odd problems with their new Broncos. @NotApplicable, please keep us updated. I hope it's something as simple as a misaligned part. Good luck
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Bummer! Please file a report with your dealer & tag @ “fordmotorcompany” in your original post. Anything we can do to highlight these issues may help encourage Ford to respond.
Let us know how this shakes out. Good luck.
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
Let us know how it goes with your dealer and Ford.
ThunderSquatch
Chester County, Pennsylvania
Bronco BaseSquatch, (ex: RAM 1500 5.7 HEMI 4x4)
I just now stopped by my local dealer to see a 4 door Big Bend Sasquatch that they had out.
Unfortunately it appears to have the same issue, at least regarding the triangle piece not being seated correctly.
I couldn’t open it as the dealership is closed today.
604Bronco
British Columbia
www.bronco6g.com
Looks like @FordMotorCompany isn’t a member on here anymore. Well, that was short lived and super unhelpful…
NotApplicable
BEVs
Ford Bronco 567 miles/10 days in, door wearing through rubberized strip down to metal 97D9EED3-D639-4322-B424-933B105E9C0E
I think that is actually “correct” if you’re referring to the bulging at the top. The window pocket is looser there, for whatever reason
