You are confusing reality with hope.
Let’s keep it simple.
You’re ridiculous post has no bearing on anything. Even where the axiom, not law was developed from, is no longer even the case. Eventually everything reaches its limit. Let’s look at compute abilities which is what the non-law was developed for. It is reaching its limit. Although not there yet we are close. It has to do with the size of the compute area. You can only go so small with the transistors and so far apart.
However here there is an actual viable next step. Quantum computing. It is already in use but has a very limited use set currently. But there is technology there actual physics to support it.
Now let’s look at batteries. Current battery technology is about as far as it can go. There is no more head room from breakthroughs but there is for refinement. So you will see some improvement but nothing major. And this based on reality as well. To repeat myself but still based in reality… you can only push so many electrons through a substrate so fast so many times until it is completely destroyed. The faster you push them the faster it degrades. This is simple physics and reality.
So taking that beyond basic understanding… you clearly see the limits and where it is being held back.
There has to be a new magic battery made that will allow for Lego kit range and faster charging. That is impossible with the current type of batteries. It is not based on today’s technology but the way batteries work. Period. So there needs to be a new magic battery found. It’s simple and there are absolutely no legitimate contenders to do that.
It is not a knock on the technology but accepting it for what it is. Look at almost any pure electric car. It can out accelerate my gas powered V8 Mustang like I were going in reverse. But I can go on a road trip in it if I wanted and not have to plan a route with dozens of stops to charge it.
And no cares what silly insults you would call people. Stick to the topic at hand.
Both of you did a little Google searching on Moore's Law which is great. You learned something today you had no idea you would. I didn't try to insult anyone, I sure didn't call anyone an insulting name. Anyway, correct, Moore's applies to transistors and is more about computing area. By reducing size it increases computing power/speed. This is what let's us hold PC's in our hands and stream real time. It is a law, wether you or I want to call it one. A theory that becomes PROVEN, is a law. Thats science, not like Covid vaccine or gender identity stuff, but actual science.In 1965, Gordon Moore posited that roughly every two years, the number of transistors on microchips will double.
This is not a law, and has nothing to do with what your discussing here, and just isn't true in general for microchips either.
Technology will advance, but it's because real people are doing real work. Not because of some imaginary law making things so.
So its not, like I mentioned in multiple post, the same thing as battery improvement but the same principle applies. Advancements in technology increase speed,performance, production, info sharing and computing of electronics. This will be the what breaks thru the EV issues. I bet your phone now can hold a charge 4-8 times longer than your first one. Similar battery materials, different ways of processing power. When Lithium batteries first came out they were/are far superior to alkaline, sorta magic batteries. Why do you think there won't be any other breakthroughs?? New materials or better processing improvements or any other advancements. It's like saying when flat screens came out TV's would not get any better. The. They got thinner and lighter and better pictures, AND cheaper.
If I insinuated that EV's (with Lithium batteries especially) will without a doubt be the predominant vehicles produced then I apologize because I have NO way of knowing that but saying that it'll never happen is just kinda silly to me. So apologies if I hurt any feelings. Not my intention arlt all. After all it's a Bronco forum, even though most of us still can't get ours.
