WS received. You were right, I got it yesterday.@Trigger WS YET??????
Mine was early 8/3. Same thing: have a tear tag but still says āIn ProductionāEarly 8/3 blend for me.
Modules/tear tag appeared late last night, but still āIn Productionā. I ordered the roof rack though and Iām fairly confident that isnāt installed on the main assembly line, so I would expect my order to take slightly longer to get through production.
Donāt know about the Bronco specifically, but typically takes 15-18 hours to finish a vehicle, so I was hoping blend on 8/3, finished up 8/4, and shipped today on 8/5, but that probably was a bit too optimistic.
How do you see your Modules/tear tag? I have on my window sticker a blend date of of 0802 and have received no emails, and when I login in it says that we are still (4 days later) "In Production"... so does that mean it is built and sitting on a lot waiting on parts or what? Terrible communication from Ford for the last 2 years on this vehicle!!!Early 8/3 blend for me.
What is a tear tag and how do you see it???Mine was early 8/3. Same thing: have a tear tag but still says āIn Productionā
If you go into the order track app, and click on modules, it takes you to this link:What is a tear tag and how do you see it???
What a tear tag is specifically for, IDK, but I know it is a key step in completion.
The Tear Tag is a label that goes on your vehicleās PCM (or maybe BCM? I forget). That tag is linked to Fordās database, which an automobile technician can use to look up the programming for the modules in your vehicle. That programming is referred to as the āAs Builtā configuration.What is a tear tag and how do you see it???
I was actually an early 8/1 blend and received a tear tag on Tuesday morning. Still saying āIn Productionā. I do have a roof rack and engine block heater so that could be the hold up. I wonder what type of delay times those accessories are causing on averageMine was early 8/3. Same thing: have a tear tag but still says āIn Productionā
Engine block heater would probably be installed well in-advance, if you install the engine block heater after it is assembled you have to drain and completely refill the coolant system and it is a giant pain to route that cable.I was actually an early 8/1 blend and received a tear tag on Tuesday morning. Still saying āIn Productionā. I do have a roof rack and engine block heater so that could be the hold up. I wonder what type of delay times those accessories are causing on average
Engine block heater??Engine block heater would probably be installed well in-advance, if you install the engine block heater after it is assembled you have to drain and completely refill the coolant system and it is a giant pain to route that cable.
But yeah, the roof rack I'm guessing is an accessory item.
(Also... I may ping you after you get your vehicle. I didn't order the engine block heaterābut I may add it after it arrives, haven't decided yet.)
Good information! Thanks.The Tear Tag is a label that goes on your vehicleās PCM (or maybe BCM? I forget). That tag is linked to Fordās database, which an automobile technician can use to look up the programming for the modules in your vehicle. That programming is referred to as the āAs Builtā configuration.
If any of the modules in your vehicle fail in the future, technicians can use the As Built configuration to program a new module with the vehicleās original programming.
Itās not intended to be used to track the build status of a vehicle, but weāre kinda hijacking the system and using it as a signal that the vehicle is actually progressing down the assembly line.
Also an 8/9 build with noHere is the link again for you 8/1 heroes. Hope you keep filling it out; it gives many of us hope. I am sorting your spreadsheet a bit and putting build days together. Hope that helps you see trends, dates, etc. Clearly I have nothing to do with my build week spreadsheet yet .
Yes, it is Thursday afternoon and I don't have a window sticker for my "build" next Tuesday. Confidence isn't high.
8/1 Build Week Spreadsheet
You are correct in the fact that any and all accessories are not installed on the line. This even includes Wildtrak hood graphics so Wildtrak builds and anything with roof racks, tube steps, etc. tend to take a bit longer to show "built" and "in transit". Hopefully there is no back logEarly 8/3 blend for me.
