Status
Not open for further replies.
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
Bronco RTR ROVR // Built for Adventure
The spirit of adventure is rekindled with the unveiling of the Bronco RTR ROVR. This vehicle package is a manifestation of our relentless pursuit to offer a holistic package that's geared toward those who seek adventure.
The Bronco RTR ROVR isn't just a vehicle package; it's a statement that resonates with outdoor enthusiasts who crave the unknown. Building upon the legacy of the Bronco RTR, the ROVR package is a canvas of self-expression for the modern adventurer, offering an all-encompassing suite of features that not only tackle any off-road challenge but invite them. Continue reading to learn more about the all-new Bronco RTR ROVR.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR-FRONT-SEMA-HERO
Standard Components
  • RTR Grille w/ LED Lighting & Modular Center Bar
  • RTR Roof Rack w/ (2) Molle Accessory Side Panels
  • RTR Tubular Front Bumper End Caps
  • RTR Rock Sliders
  • RTR Rear Bumper
  • RTR Spare Tire Carrier
  • RTR Rear Molle Accessory Plate
  • RTR Adjustable Tailgate Stop
  • RTR ROVR Lunar Graphics
  • RTR Lightbar w/ (5) PROJECT X FF.70 Lights
  • RTR Front Bumper Light Mount Kit w/ PROJECT X HP.70 Lights
  • (5) 17x9 RTR Tech 6 Wheels (Satin Black or Satin Charcoal)(+0 or +30 offset)
  • RTR Billet Spacer Lift (Required for Non-SAS equipped Broncos)
  • (5) Nitto Recon Grappler 12.5x35R17
  • RTR All Weather Floor Liners
  • RTR All Weather Rear Cargo Liner
  • Lug Nuts and TPMS
  • RTR Key Fob Clamshell
  • Certificate of Authenticity
  • 3 Year / 36,000 Mile Warranty (from In-Service Date)
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR-REAR-HERO
Design Meets Functionality
At the core of the Bronco RTR ROVR lies the innovative RTR Roof Rack w/ Molle Accessory Side Panels, that blend off-road capability and versatility. The RTR Roof Rack w/ Molle Accessory Side Panels was designed to seamlessly integrate with any 4-door Bronco equipped with a hardtop or soft top. It also utilizes factory mounting points to ensure rigidity and durability. The Roof Rack is constructed from ⅛-inch tubular steel and 30mmx60mm heavy-duty aluminum t-slot crossbars. The tubular steel is finished with a black powder coat and the t-slot cross bars are anodized with a black finish. With all of this, the overall height is only increased by 3.625 inches.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles JCOL9147
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles JCOL9287
Large Molle Accessory Side Panels flank each side of the RTR Roof Rack and feature numerous mounting locations for all of your accessories that you may need on your next adventure. Combined with the RTR Roof Racks integrated t-slot crossbars you can add rooftop tents, cargo boxes, or recreational outdoor equipment.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-12
Your Journey Illuminated
As the sun dips below the horizon, the RTR Light Bar w/ (5) PROJECT X FF.70 lights and front bumper-mounted PROJECT X HP.70 lights take the spotlight. Not only does the RTR Lightbar w/ PROJECT X FF.70 lights, cut through the darkness to light the trail ahead but it is an integral part of the RTR Roof Rack’s structure. The lightbar provides a mounting point that seamlessly integrates into the roof rack without adding additional mounting points.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-19-2
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles JCOL9214
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles JCOL9209
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-10-2
Navigate Your Next Adventure with Confidence
No adventure is without its obstacles, the Bronco RTR ROVR is well equipped with components that will turn those obstacles into stepping stones.
RTR Components such as the RTR Spare Tire Carrier, RTR Rock Sliders, and RTR Rear Bumper further enhance Bronco RTR ROVR’s off-road capabilities.
The RTR Rear Bumper allows for greater departure angles while you’re on the trails. It is constructed from 1.75-inch DOM (Drawn-over-mandrel) steel tubing that can withstand even the most demanding trails. The RTR Rear Bumper also includes welded D-ring shackle mounts, and a removable license plate holder, and is compatible with the OEM parking sensors and hitch.
On the tailgate of the Bronco RTR ROVR, you'll find the RTR Spare Tire Carrier and Molle Accessory Plate. This setup allows for additional mounting locations for an off-road jack, jerry can, or any accessories that you may need on your journey.
RTR Rock Sliders are built to perform under the most rigorous conditions, adding a functional lift point and 4 inches of step to your Bronco. Bronco RTR Rock Sliders feature a 7-inch rear kick-out that helps you slide across larger obstacles and doubles as a step to help you reach your gear mounted on your roof.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-3-2
Elevate Your Off-Road Experience
You never leave for an outdoor trip without the proper gear that’s why the Bronco RTR ROVR is equipped with 35-inch Nitto Recon Grapplers and 17-inch 12.5x35 RTR Tech 6 wheels. There are two wheel color options to choose from, Satin Black or Satin Charcoal. Non-Sasquatch-equipped Ford Broncos will have the RTR Billet Spacer Lift installed which will increase ride height by 2 inches. Tread on any terrain with Nitto Recon Grapplers. We chose the Recon Grapplers because they combine superior off-road capabilities without compromising on-road driveability.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-15-2
Extraterrestrial Surface Contour Graphics
The ROVR Graphics package consists of topography from different space exploration missions throughout history. The hood and a-pillar graphics are inspired by the first Mars Exploration Rover mission, Mars Pathfinder. The Sojourner Rover landed in a river basin called Ares Vallis. The topography of Ares Vallis is adorned on the hood and a-pillar graphics.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-4-2
The driver-side and tailgate graphic features the mission plan and topography of a crater that was explored during Apollo 12 in 1969. While the passenger side is inspired by Opportunity. Opportunity was a Mars rover that defied all projections and lived actively for 14+ years, which exceeded its life expectancy by 57x. It collected and analyzed samples that helped prove water was once on Mars.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-11-2
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-14-2
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-17-2
Rounding out the ROVR’s Graphics Package, the tailgate graphic shows the depth of a crater surveyed on the Apollo 12 Mission along with the flight path of the Apollo 12 Lunar Module.
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-8-2
Ford Bronco Bronco RTR ROVR // Latest Vehicle Package from RTR Vehicles ROVR_SEMA_2023-13-2
Bronco RTR ROVR Availability and Pricing
Priced at $18,995 in addition to base vehicle cost (excluding labor), the Bronco RTR ROVR is set to be available in Q1 of 2024. An exciting new journey could be just a click away! Visit the LINK to learn more or contact an RTR Customer Service Representative. Vehicle packages are available through our Authorized RTR Dealer Network or we can build it for you at the RTR Lab through our Built by RTR Program.
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Interested in details on the roof rack!
WilVis
Northern Utah
Ford Bronco
I am still processing what I am seeing. Is this for lunar use or will it work down here where the oxygen is?
The roof rack looks sweet. And I miss the A51 color.
DoubleK
Ken
Las Vegas
21 BaseSquatch
Imonamoose
Moose
Earth
Truck
Knowing its an RTR product, probably gonna be $4k
Lol, clearly someone didn't last to the end... $19k for that package not including labor.
I would do this al'acart but those guys and their pricing are on another planet.
Gtrekker
Gary
NJ
Standard Components
  • RTR Rock Sliders
  • RTR Rear Bumper
  • Lug Nuts and TPMS
Nice stuff...Don't forget at us 2drs.....
DoubleK
Ken
Las Vegas
21 BaseSquatch
Clearly someone didn't read that I was replying to someone about the roof rack specifically.
Imonamoose
Moose
Earth
Truck
Yea, I was too excited to make the lame "other planet" joke... oh well, ya can't win em'all. 😏
I do like that rack, though. Sure do hope it's in the 2k range but you are probably right.
Lil Mul
2023 2DR Badlands SAS / 2016 Mustang GT PP
Let me guess. Out of stock ? like everything else in the RTR store ?
Sean6365
Sean
23 Bronco Raptor, 08 Dodge Ram 1500
Status
