- Jul 9, 2020
- 31
- 1,758
- 4,160
- Pittsburgh
- 2018 Honda Pilot
- Badlands
Come on Ford
Fun fact, the tires that come with Sasquatch are a all terrain. The M/T in their branding stands for multi terrain, not mud terrain. Those tires are what they call “hybrid” which is just a fancy name for a more aggressive all terrain tire.Come on Ford
Really? If true, this made my night.Fun fact, the tires that come with Sasquatch are a all terrain. The M/T in their branding stands for multi terrain, not mud terrain. Those tires are what they call “hybrid” which is just a fancy name for a more aggressive all terrain tire.
It’s a very common misunderstanding. I think it was a bad decision to label them as M/T because every other tire manufacturer that I know of calls that a mud terrain.
Gotcha thanks!!Fun fact, the tires that come with Sasquatch are a all terrain. The M/T in their branding stands for multi terrain, not mud terrain. Those tires are what they call “hybrid” which is just a fancy name for a more aggressive all terrain tire.
Yes. Honestly I’m too lazy to look it up and post it here but Goodyear put out an article about these tires. It’s on this forum somewhere. And obviously easily found using a Google searchReally? If true, this made my night.
I’ve seen this a few times and based on the tread pattern, the tire does seem to be an AT. But even the Ford survey called it a Mud Terrain tire so I’m not sure.Fun fact, the tires that come with Sasquatch are a all terrain. The M/T in their branding stands for multi terrain, not mud terrain. Those tires are what they call “hybrid” which is just a fancy name for a more aggressive all terrain tire.
Goodyear calls it a multi terrain.I’ve seen this a few times and based on the tread pattern, the tire does seem to be an AT. But even the Ford survey called it a Mud Terrain tire so I’m not sure.
This is clear as mud...sorryI’ve seen this a few times and based on the tread pattern, the tire does seem to be an AT. But even the Ford survey called it a Mud Terrain tire so I’m not sure.
Ah I gotcha. I’ll trust Goodyear over Fords marketing team for sure then. Thanks for clearing that upGoodyear calls it a multi terrain.
Will you add an R/T Hybrid tireCome on Ford
