A51 Delivered today - Pinch weld painted / sidesteps.
Hornet
Ford Explorer
Just took Delivery today A51 Big Bend 2.3L MID MIC with sidesteps. First order of business was painting the pinch weld above the sidesteps. I think it turned out great. 102 miles on the odometer when I picked it up.
10/29 Window Sticker
11/4 Blend Date
11/8 In Production
11/8 Modules popped
11/9 Built
11/10 Awaiting Shipment
11/15 Delivered.
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. 24CDFD3C-C203-43AE-B6E1-D915B565ED3E
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. 52375EB9-83F9-4D8D-9B17-46F7FE145D78
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. AE7E3649-A64C-4249-91B9-A8E837ADAC12
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. 012FCDE7-824E-4B3F-85A1-E4E389DA0C8B
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. 8D1649CB-FC42-45BB-8553-30E361CE06A1
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. DBC00A2A-A368-4ED1-A8C8-4D72268DE082
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. F589A60D-D437-478F-97AD-1C256E8CBA9A
Headsong
Looks great, but shocked that the steps didn't cover the welds!! WTF??
Last Ride Bronco
southern USA
Nissan pup
I recommend the Lund trail armor from the accessories catalog. It not only covers the pinch weld, but protects the rocker panel from rock chips.
I put these pics in another thread, but Iā€™ll let you see these as another possibility.
BEFORE
AFTER
DesertMike680
Las Vegas
BEFORE
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. FA1D3510-4ED9-41E6-8C95-5BF4BAEE5D70
AFTER
Do you have a link to those? I couldn't find it.
Last Ride Bronco
southern USA
Nissan pup
https://ruxerparts.com/online-store/?model_number=VM2DZ-1613208-A
Itā€™s out of stock but there are other dealerships that can order like Levit town Ford. Your own dealership can order it. Probably will pay more though. Some dealerships wonā€™t install unless you buy the part from them. Hereā€™s a screenshot with the part number (4 door).
Youā€™ll probably pay 15% more through most dealerships.
DesertMike680
Las Vegas
Hornet
Hornet
Ford Explorer
Yes me too. I recently bought a Jeep Wranfler for the kids. I installed OEM steps and it mounted nicely to the weld/used existing holes for a nice clean look. I've seen some aftermarket steps for Bronco that also use the weld.
Headsong
Yeah, I've decided I'm going to go with go Rhino if I ever get my Bronco LOL or not. And I noticed that some of them don't use the pinch Weld. And some do so I'm aiming for one that does.
Rick Astley
Up Doug's ass
d
Yikes!
There are enough threads on the topic of under-seals in Bronco6g that this shouldn't have been used if a bit of searching was performed.
Good luck with it, but this most likely won't be the long-term solution you're after.
Rick Astley
Up Doug's ass
d
BEFORE
Ford Bronco A51 Delivered today - Pinch weld painted / sidesteps. DA8B4A4B-749B-49D5-A80C-DFC3BEC45AA6
AFTER
That will also see water being held against the paint until evaporated, or more moisture is applied.
Obviously not that much of a problem on a brand new car, but as somebody who has cars up to 70+ years old and patched in enough panels, you've created just another problem in need of a solution. Hopefully there is an underbody seal applied on the painted surface before you put those water traps on.
Marshhunt
2018 RAM 2500
I used a roll of grip tape to cover the weld on my Ram 2500. It covered the weld and the texture matches the power steps I added. Over 70k miles & almost 3 years later it's still stuck great.
Jmax
Plymouth
Explorer
Looks way better, huge miss by Ford IMOā€¦
mom trying to gauge my delivery. I have only received an email saying a build date first week of December. When did your email state it would be built? I see the actual build date but trying to figure out if I can expect delivery by year end for tax purposes. Sees like quick ship/receive turn around. You must be close to MI?
Hornet
Hornet
Ford Explorer
Originally scheduled for July bumped several times and finally 11/1 was the ticket.
yes I live in Michigan.
