A is for Articulation. Articulation is what helps keep us all grounded. Literally. It helps make your tires stay on the ground, even when taking on the tough types of wild that make the wild...wild.
B is for Breakover Angle. Breakover Angle is a fancy term that means "how big of stuff can I go over?" More or less. Luckily, the Bronco™ 2-Door models have available maximum Breakover Angle that's best-in-class. Which is a fancy term that means "29 degrees."
C is for Crawl Ratio. Crawl Ratios are a complicated math equation that determines the torque multiplication between the engine and the tires for crawling over big rocks. Bronco™ has best-in-class available Crawl Ratio. Which for anyone keeping track, is 94.75:1.
